nukeproof mega and ...
[Closed] nukeproof mega and double barrel
When it happens will let you know Tom. Yep to long Tom - I've got 8 weeks holiday - coming up have to get an uplift day in somewhere Revolution when it stops raining maybe?
Posted : 24/06/2012 3:18 pm
Revolution is a bit far for a day but a mid week FOD would be good, or a Sunday with all the mtbb lot 😀
Posted : 24/06/2012 4:02 pm
TFT won't tune the monarch, they hate them.
I doubt going to a monarch plus will change much. It still has the spring rate characteristics of it's little brother but with a piggy back to cope with heat generation on long downhills.
Oh yeah and the Dual Position Air fork is divey as **** and your only saving 200 grams over the U-turn! Silly choice!
Posted : 24/06/2012 6:38 pm
Hard to put my finger on it exactly but it doesn't feel as plush as my Reign felt. Putting a coil shock into my Reign was a revelation. It felt so planted and really felt a bit like my DH bike used to feel.
The same coil in the Mega just feels a bit.....meh.
The Monarch RT3 seems to feel fairly stiff and not so smooth when riding generally. I've played about with the sag but low enough to feel plusher means I max out the travel a lot.
Its a solid platform climbing etc, but downhill it just seems that it could be better, could feel as good as my Reign used to feel.
The Reign is a virtual pivot point bike, the Mega is a single pivot. Of course the shock tune needs to be different. Considerably different!
The Mega btw was given a reasonably racey firm ride to make it poppier and more controlled with an airshock. It was never going to be quite as plush, unless you find a shock with a lower compression tune.
Posted : 24/06/2012 6:48 pm
i am a bit loathed to go coil due to weight and whole linear bit
😯 Linear is good, progressive air shocks are what cause midstroke wallow. If you are really bothered about the linearity, get an RC4 tuned and then shove a bit more air into the chamber and bump up the bottom out control. You probably wouldn't be able to use all of the travel, but hey!
Do you guys even know a smidge about suspension tech? I know **** all but more than some of the shit banded around on singletrack.
How long have you ridden the Monarch? It took about 40 hours of riding time before it felt like it had good small bump sensitivity, I still don't like the spring characteristics of air shocks though. I might get on more with a Vivid Air though, that was designed to mimic a coils spring rate I believe.
TBH I like the Monarch on the Mega more than the previous DHX5 on my old four bar linkage 08 SX trail.
Posted : 24/06/2012 6:51 pm
Thv3 I notice your not running the protective sleeve on your CCDB? Do you not get any rubbing?
Personally I'm kind of with bwarrp on this one I wouldn't spend my cash on the monarch plus based on my experience with the standard one.
Posted : 24/06/2012 8:42 pm
Not really as silly choice to me - maybe to you in your "expert" opinion.
Not changing forks to loose weight - just want some new forks cos I can afford them plain and simple.
The DPAs I rode felt fine to me - had a good a few hours riding a pair.
Posted : 24/06/2012 10:18 pm
The mega comes with a HV air can. HV air cans are generally softer in the middle and ramp up more at end of travel in comparison to a coil, the issue people are having with their monarch shocks on the megas. A standard volume air can is more progressive than a coil all the way through the stroke, no saggy middle.
As for the force displacement curves shown with various shock springs, be interesting to know what data was entered for both types of air springs, whether they are actually based on any particular air shock on the market or just guesses. It also looks like the plot has been produced with a stiffer coil spring than air springs, exaggerating the difference.
I think people are being to quick to dismiss the air shocks on their megas for silly made up reasons, when slight alteration in air can volume could be achieving the results they desire.
I also have nothing but glowing feedback for the monarch plus rc3 shock.
Posted : 24/06/2012 10:37 pm
We are guilty of justifying our desire for
Upgrades 🙂
Posted : 24/06/2012 11:01 pm
So true! I wouldn't dismis air shocks as such, I wouldnt mind giving something like a vivid air a try or even just an Rp23 but for my riding a coil suits me best having come from downhill bikes in the past.
Posted : 24/06/2012 11:38 pm
thv3- CCDB fan here!
Just wondering where u got ur CCDB from?
Does anyone know dealers other than TF Tuned?
I will be getting one after my summer hols with the missus, if I have any money left over that is! I dont know whats a bigger drain on my finances just now. Her or the bike! Lol
Posted : 25/06/2012 3:17 pm
The you run into issues with being unable to use all the travel when you move to a low volume can.
Posted : 25/06/2012 4:01 pm
I spoke with the guys at TF Tuned today and they said that the Mega is great with a coil shock. And if going for one. The vivid is good, but has high repair costs if anything goes wrong/gets damaged. Where as the ccdb is not too costly to repair and can be modded to fit any other frame after for about 150quid. So if I changed frame I could keep the CCDB. I have plenty time to mull it over as I have wedding and honeymoon to worry about just now.
CCDB is looking like my choice if cash is good for it! Or a Vivid if cant manage the CCDB. Will post my results once I have done the swap!
Posted : 25/06/2012 11:36 pm
Sweet. Vivid it is then, I don't feel like doing my head in with so many adjustments. I get obsessive enough as it is, what tune did they recommend?
Posted : 26/06/2012 1:54 am
Vivid has the same number of adjusters 😉
Posted : 26/06/2012 6:06 am
 thv3
CCDB on the mega doesn't need a sleeve, no rubbing at all, works perfectly.
Posted : 26/06/2012 7:27 am
Bwaarp- I never got as far as asking tunes. Will do that when I am purchasing. Very helpful on phone so just give them a call. Not pushing for sales so will give you info I think.
Legend- quote from tf tuned site " the Vivid is durable and adjustable with controls to let you dial beginning and end stroke rebound as well as low speed compression". So it has one less compression adjustment over the CCDB.
The reason I'm choosing the CCDB is because I'm still young, I will no doubt have at least one more AM style frame before I get old and go XC! lol. So I will beable to swap the shock over with minimal hassel.
Posted : 26/06/2012 7:58 am
Just off the phone to Hotlines who are main distributor for Nukeproof. They are going to call me back.
The guy I was speaking to had just fitted a RS Monarch Plus and says its good, but he did recommend the Mid/High tune option.
He also said the CCDB would be the better choice over a Vivid purely for the shock tunes which can be done on the CCDB will suit the frame better.
He thinks that Nukeproof have been testing the CCDB on the Mega with the thoughts of releasing it as an option upgrade. Once he calls back after speaking to Nukeproof I will post an update.
Posted : 26/06/2012 10:41 am
What Ti spring are you using, I have got just a steel one on my CCDB and it rubs the sleeve.
Posted : 26/06/2012 11:05 am
Yes, from what I've heard through a bike shop that sells a lot of Nukeproof, they are bringing out a Mega with a redesigned linkage with 160mm of travel and the option for either a Monarch Plus or a CCDB.
You can get the Vivid from Germany for 190 quid so I would prefer to spend that over 500 quid for the CCDB if at all possible,
Posted : 26/06/2012 11:26 am
Ok, interesting. Is it a redesigned frame or just the linkage?
I think the vivid would be fine. Prob best to ask TF Tuned though.
Posted : 26/06/2012 11:35 am
I'm not so sure, I will be slightly irate if it's a new frame but the rumours I've heard is that it's just a new link.
It's all rumours though, however I've heard the same from a few other independent people connected to the bike industry.
Posted : 26/06/2012 11:41 am
I just spoke with my local bike shop where I bought my Mega from.
He is going to make a couple of calls and get back to me. He said there has been quite a few rumours flying around just now with Nukeproof. So will see what he says.
If true it changes my plans completely and I will wait for new Linkage. If Hotlines phone me back I will ask them also.
Posted : 26/06/2012 12:03 pm
Nice one Gdub, if it is the case I'll wait for the new link and save up for a CCDB in the meantime.
It could well be bollocks though, let us know!
I don't think Nukeproof realized how much of a hit the Mega would be with ex-downhillers, so underestimated the amount of people who want coils on the bike as opposed to XC derived air can! I don't know of any other bike that has quite so many posts titled "Can I fit a coil on a Mega" etc.
Posted : 26/06/2012 12:08 pm
in the words of my local bike shop from hotlines, "utter bollocks!" They also said why would we mess about with a Bike which Dirt have just reviewed as one of the Best 150mm Travel bikes out there.
So thats made my choice a bit easier, still between RS Monarch Plus and the CCDB.
The rumours you might have hearing about is the fact that Nukeproof are testing a large range of shocks on the Mega to see whats best.
Posted : 26/06/2012 12:10 pm
Cool, okay! Must have been a typo, the shop supposedly got a catalogue listing the 2013 parts that listed the bike as having 160mm of rear travel, with two shock options. Rumours hey? Nevermind!
I would go for the CCDB or the Vivid Air (I have not heard great things about the CCDB air). I don't think the Monarch would be a good enough upgrade, it's not going to offer any more midrange support unless you go with the low volume option and then you can run into other issues.
You could perhaps, import a tuned RC3 Plus from Push. They informed me that they could offer a shock with more midrange compression support on the rear.
Posted : 26/06/2012 12:13 pm
I haven't seen the new catalog, but I find typos all over the place in manuals and catalogs which I use for work.
I have also heard that the CCDB air is not going quite as good as expected, but its a new product, and you will get teething issues. The mega has the welds snapping on the chainstays on a limited number of bikes too, but thats been sorted now.
Hopefully you have luck with what ever shock you fit.
Post you results as it will be interesting to hear whats good.
Posted : 26/06/2012 12:20 pm
Doh. In my mind it had high and low speed compression too
Posted : 26/06/2012 12:45 pm
If the vivid had High and Low Speed compression, that is the shock I would be getting.
It would match up perfect with my Lyrik RC2 DH forks.
Posted : 26/06/2012 12:50 pm
High and Low speed rebound is more important than compression. The classic way of altering how a shock sits in its travel is through rebound.
The Rock Shox engineers have previously stated they think the same way, do you think they would design a shock that doesn't match perfectly with their own fork? I would place a bet that you would get a balanced suspension set up more quickly with the vivid than you will the the CCDB, but that with the CCDB you may be able to tune it in a little more to your taste.
I'd rather go with a shock that I'm not going to mess up to easily like you can with shocks with broad ranges of adjustments like the ccdb.
Then again, as others have said, the choice of the preset three high speed compression tunes, that you get with the vivid, may not be perfect for the Mega.
Posted : 26/06/2012 1:49 pm
Somewhere on the Rockshox website it says the Monarch Plus is the shock to match up with the Lyriks.
My main thought is its still an Air shock. If a Coil is going to do the job better, thats what I am going to go for. Otherwise it will be a Monarch Plus.
Posted : 26/06/2012 1:56 pm
I think as long as you stick to the same manufacturers shocks, they all do. The Lyriks just feel like a smaller version of the Boxxers to me etc.
If you realy must go with an air shock, I think the Vivid Air on the rear would be a good complement and only 200 grams heavier than the Monarch. Even with a Titanium coil the vivid air is still a fair bit lighter! There have been a few guys running them on Megas over at MTB-News.De, whilt a lot of downhillers really rave about the shock.
Here's a nice review! I don't entirely agree with it, I still prefer my coil shocks.
http://www.vitalmtb.com/product/feature/Real-Life-Comparison-Vivid-Air-and-Vivid-Coil,32
Posted : 26/06/2012 2:02 pm
I hadn't thought about the Vivid Air, partly because I didn't know they did a 200*57mm size.
I will make my decision once Hotlines call back with the Feedback from Nukeproof directly.
I think the Lyriks are awesome and got them set up and dialed in fairly quickly. Only time they are not so good is when I land front heavy....so can only blame my self there though
Posted : 26/06/2012 2:16 pm
Mega with a Vivid Air, it looks good! :mrgreen:
Posted : 26/06/2012 3:05 pm
Just off the phone with Hotlines.
Nukeproof have been testing the CCDB Coil Shock on the Mega and are very pleased with the results!
Also, the Mega Linkage will NOT be getting changed, and the Mega is unchanged for 2013 also. So it wont be 160mm travel in the near future.
It does look nice with the Vivid Air but I think I am going to go the whole hog and get the CCDB as I have a small Black and Gold theme going on.
Will Try get a pic up soon of current setup and after.
Posted : 26/06/2012 3:24 pm
[img] http://www.pinkbike.com/photo/8272741/ [/img][url= http://www.pinkbike.com/photo/8272741/ ]My Bike[/url]
Posted : 26/06/2012 3:25 pm
Gdub, I'm glad your bike wasn't the custom paint job "goldfinger style" black and gold Mega I have seen floating around here. :mrgreen:
I look forward to hearing how it rides! Did they give you advice on settings?
Posted : 26/06/2012 4:19 pm
no, I have not done any anodising to my bike 🙂 lol, I have seen that one too.
No custom tuning required, and if I order from TF Tuned they will do a base setting for me, if I order from somewhere else it will come as the factory base setting which is middle of the road on everything.
Posted : 26/06/2012 4:25 pm
Vivid looks smart! I'm glad nukeproof may be offering the CCDB as an upgrade it's defintely worth it if anyones thinking about it.
Posted : 27/06/2012 3:20 pm
Yep - would call it more trailer trash style. Often seen around teh FoD 😯
Posted : 27/06/2012 5:56 pm
Def not my bike. I have some suttle gold bits like saint shifter and mech and bolts on the white e13 guide. Im bad for doing colour purchases. But my mates keep me sensible.....ish! 🙂
Posted : 27/06/2012 6:32 pm
Guys, big issues with the Monarchs! Stay away!
http://forums.mtbr.com/shocks-suspension/pushed-monarch-shocks-no-more-783968-2.html
Posted : 29/06/2012 5:33 pm
Er? There's nothing wrong with Monarchs it's just Push aren't offering them any more due to their own issues from what I've read.
Posted : 29/06/2012 5:45 pm
No, they are not offering them because the modified shocks they sold were constantly being returned to them with issues that SRAM/Rock Shox caused. They are having to rectify the issues with the modded shocks they sold as the warranty is with them not SRAM.
Read more carefully. You bought the wrong shock mate. As usual air shocks are ****ing shite!
Posted : 29/06/2012 6:43 pm
First I've heard of it 😀 I think there's a lot more to the story than a bit of reading between the lines.
Posted : 29/06/2012 7:10 pm
Page 2 / 3
