Nukeproof ARD Tyre ...
[Closed] Nukeproof ARD Tyre Insert
Hi all,
Does anyone know when CRC will have these back in stock, or if there is any other retailer that holds stock?
My online search has been unsuccessful.
Need 27.5.
Thanks
Posted : 20/12/2018 12:49 pm
You specifically want the Nukeproof one? I only say as a company from Bristol called rimpact make them. They are £35 a pair with valves! Bargain I thought
Posted : 20/12/2018 1:05 pm
I have been looking at the ARD specifically as I like the shape. It looks like it would offer more rim protection than the likes of Huck Norris, etc...
The Vittoria Air Liner and Cush Core seem expensive, essentially when the'd do the same job as the ARD, which is half the price.
Good shout on the Rimpact though. I'll have a look.
Posted : 20/12/2018 1:14 pm
https://www.rimpactmtb.com
At that price I'd certainly give them a go if I was going for inserts. The lads who developed them are pretty handy riders so the inserts should be up to hard riding.
Posted : 20/12/2018 1:15 pm
On the Rimpact subject, has anyone used, or is currently using them?
Posted : 20/12/2018 1:19 pm
No but I plan to be! A mate said they will be at Malvern classic this year setting them up but that’s a while to wait! They have a few how to guides by the looks of things so should be fairly easy? Famous last words..
Posted : 20/12/2018 1:29 pm
I'll have a look on YouTube later for install videos etc..
I'm holding fire on ordering my new wheels as I want inserts first, so if the Nuke are out of stock I might go for these as they look really good, and reasonably priced too, especially with valves.
Posted : 20/12/2018 1:39 pm
In stock at Pearce Cycles in Ludlow.
Posted : 20/12/2018 3:39 pm
Dilwyn, do you have a link as I can’t seem to find them?
Posted : 20/12/2018 6:55 pm
I think cycle factory in tod had some.
Posted : 21/12/2018 11:18 am
Pulled the trigger on Rimpact. Was chatting to Matt over email last night and I was really impressed with his service. Can't fault the price, £35 with valves.
Also ordered some Halo Vortex wheels so this should be a killer combo.
On the wheels subject, I now have a pair of Hope 35W on Pro 4 hubs (27.5), so if anyone is interested hit me up 🙂
Posted : 21/12/2018 12:26 pm
Please do report back on how they are. I'm interested in getting an insert for the rear.
Posted : 21/12/2018 9:38 pm
 spev
Hotlines say end of Jan 2019
Posted : 21/12/2018 9:56 pm
If those rimpact are anything like the panzer tyre insert (which they look to be) then they were a pain to fit but seemed to work well, not had a puncture yet.
Posted : 23/12/2018 12:28 am
Not fitted yet, but expecting a little hassle.
Hoping to get them on this week.
Posted : 26/12/2018 1:00 pm
Ok. So I’m waiting for a rear tyre so only fitted the front, but what a doddle. Probably 10 minutes from start to finish with no swearing.
Tyre went on easy with no need for any soapy water (Minion 2.5 WT).
100 psi in the inflator (normally 160) and slowly controlled the flow. Tyre popped first time. Happy days.
Rimpact valves are nice too. Well thought out.
Hoping my rear tyre arrives soon for a NYE ride so I can start playing with pressures.
Posted : 26/12/2018 9:58 pm
Are the Rimpact valves specific to their rim protector? I.e. could you use Stans valves?
Posted : 27/12/2018 10:27 am
Not sure if you can use other valves to be honest.
The Rimpact valves are slightly different. As the insert sits on top of the valve normal valves would get clocked as air couldn’t pass, but the Rimpact are different, as air exits the valve from the side by 3 to 4 holes, if that makes sense. Check the website, you’ll see what I mean. The valves are nice. 10 times better than the Uberbike valves they’ve replaced.
Posted : 27/12/2018 8:18 pm
That makes sense, I think I am going to give them a go too.
Posted : 28/12/2018 5:29 pm
Ok. So rear wheel done. Again, 10 minutes max from all bits to fully inflated. Fitted the new tyre (Maxxis DHR WT 2.4) then insert. Tyre went on easy (Halo wheels) and seated first time. Again, inflator at 100 psi and air flow controlled.
As far as fitting goes I’d 100% recommend them.
First ride tomorrow so hoping for trouble free riding.
I think these inserts will provide great tyre support, and play a massive part in stopping dents & dings.
For £35 all in (plus postage) I’m happy.
Posted : 29/12/2018 10:50 am
That's good to know, mine have been shipped today 🙂
Posted : 29/12/2018 11:28 am
Let me know how you get on mate.
Posted : 29/12/2018 12:30 pm
That’s good to hear they are easy to fit. I imagined a nightmare getting a tyre on with them. Better eat some ordered then!
Posted : 29/12/2018 12:43 pm
Wasn’t hard, just a little more fiddly.
You do get fitting instructions but I did it my own way.
I just fitted the tyre to the rim, fitted the insert then seated the other bead. As the insert provides more support the tyre bead hooks the rim better so inflating first time is a doddle. Mine went up without using any soapy water.
Posted : 29/12/2018 1:09 pm
I installed Rimpact in tires that were already mounted. It was as easy as installing a tube. Hopefully they aren't too soft to do any good.
Posted : 29/12/2018 11:28 pm
I spoke with rimpact the other day regarding my rims/tyres as there 29 inserts are for 25-35 rims and 2.3-2.5 tyres, my crest rims are 23 and run 2.25 tyres, they told me they are currrntly testing and should be available February some narrower inserts for more xc set ups, very helpful guy, thanks
Posted : 30/12/2018 9:34 am
Cheers for the heads up about these, my Huck Norris setup needs replacing so I’ve ordered the Rimpacts, I’ll see how they go, but for the price they seem pretty good!
Posted : 30/12/2018 9:36 pm
Is the foam closed cell? Interesting. Im still on procore. No issues since sept just have to do everything twice when it comes to the dual chamber system. It does lose air. Even the inner tube. few psi per day.
Trying to get on halo's site and the shop is offline 🙁
Posted : 31/12/2018 12:31 am
Yes, they’re closed cell are are one bonded unit.
Do you run Halo wheels?
I’ve just fitted the Halo Vortex, and they felt insanely strong yesterday running the Rimpact and Minion 2.4 / 2.5 WT combo. And not to mention that freehub sound 🙂
Was running about 25PSI but might experiment with lower pressures.
Posted : 31/12/2018 9:58 am
Halo site is back up. Just ordered some. Any WT rubber and 30mm ID rims at 90kg im usually 20psi-22f 25R. I will try the insert with these. The Rimpact looks soft but they seem large enough to really cover up the tyre beads under compression.
Posted : 31/12/2018 12:02 pm
I wonder what's the difference in behaviour between ARD and Rimpact, as Rimpact fills more volume in the tyre...I'm torn between the two systems but not sure which way to go.
Posted : 31/12/2018 12:53 pm
I had a chance to try out Rimpact yesterday, and it did seem to protect my rim. I dropped the pressure of my 2.35 Hans Damph 2 from 25 to 22psi and the increased root traction was noticeable. I did hit a few rocks on the way down and didn't feel any rim strikes. I plan to play around with pressure and some high speed descending if the weather cooperates.
Posted : 31/12/2018 2:51 pm
 Alex
Similar. 32mm American Classic wheels. Now they’ve gone bust I want to keep them going as long as possible. I really like the wide lightenings. I’m fitting 2.5 and 2.35 new tyres onto these rims.
Mate has cushcore. Seems to work but blimey they were a nightmare to fit and the one day we had to put a tube in…… well let’s just say I never want to do that again!
Posted : 31/12/2018 5:45 pm
Few rides in on a pair of rimpacts, feel pretty good, installed for support without going to dh tyres, seem to be doing the trick.
Posted : 31/12/2018 5:53 pm
I appreciate there are loads of variables at play here, but as a snapshot, once fitted, how much do you drop your PSI by?
Posted : 31/12/2018 6:24 pm
Mine arrived today, will install them when my new tyre is delivered and hopefully try them out at the weekend.
Posted : 31/12/2018 7:15 pm
 Alex
Turned up, fitted with some lovely new Schwalbe rubber. My mate reckons they aren’t has hard to install as CushCore but still requires a bit of effort. Might have helped if we’d read the instructions.
Going to start with my normal tyre pressures and see how we get on. It’s a big loop of Brechfa tomorrow so plenty of time for faffing. Shall report back.
Posted : 04/01/2019 6:13 pm
Just installed mine, had trouble with the new tyre when I got near the end of getting all the bead on. Pushing the bead into the well of the rim all the way round to give some slack helped and meant no tyre levers were needed. Also tested taking it back out and it is easy enough so could be done on the trail if a tube is needed. Hopefully first ride on them tomorrow.
Posted : 05/01/2019 6:39 pm
Re the Rimpact valves...
Does anyone know if the cores are removable? (Can’t see it anywhere on the website) or do they not advise adding sealant that way?
I’ve never got on with removing bead and pouring it in
Posted : 05/01/2019 9:25 pm
 Alex
Ride done. Black and Red at Brechfa Forest. That’s a big ride, not super rocky but lots of different surfaces - roots, hardback, pud, few rocks, etc.
Previous setup American Classic Wide Lightenings (32mm external) with Maxxis DHR 2.5 (Front) and DHF 2.4 (rear). Both WideTrail. Ran 23 front, 21 rear mostly. More when it was rockier.
New setup. Same wheels. Schwalbe Magic Mary 2.35 (should have been a 2.5 but wrong one sent and I’m impatient so I went with it) Orange Stripe, Hans Damf 2.35 Blue Stripe. Started 23/21 as well.
Definitely more support with the Rimpact inserts in there. Tyres felt too hard. Dropped them and kept dropping them until they were on that sweet spot between not floppy but plenty grippy. Ended up at 19 rear and 17 front.
There is definitely something about damping. That bike (my RipMo) is very good at damping trail buzz but I think these add something. They certainly make the tyres feel tough even at low pressures. Didn’t notice any increase in weight but the new tyres are lighter than the Maxxis pair.
I need to ride some more obviously. No one had any punctures today so it’s hard to know if they offered anything there. A ride down the Gap would be a better test. So far tho, happy with the experiment. I just need to find a 2.5 magic mary!
Posted : 05/01/2019 9:42 pm
 Alex
Defo removable. I used JRA milk in mine and didn’t have an issue getting it through the small holes in the Rimpact valves. Stans may be thicker?
Posted : 05/01/2019 9:43 pm
Cheers guys,
thought they would be removable, but wasn’t sure about the horizontal holes and wether they’d clog or not
Currently using standard stans fluid
Posted : 05/01/2019 10:09 pm
"Alex" just for balance my Cushcore took around fifteen minutes the pair to fit and went up with just a track pump. The Maxxis tyres were used so maybe made it a little easier. Heard they may be difficult to remove.
Had plenty of experience with Metzler Six-Days tyres tho.
Posted : 06/01/2019 10:06 am
 Alex
@downhilldave - removing was the real problem. My mate has some lovely Syntace carbon rims. They are *very* tight on the bead tho. He had a tyre failure - split right in the bead and we couldn’t plug it. Took us a long time to get the tyre off.
50% I reckon was the rims, 50% the fact the cushcore was filling the gap so we couldn’t get any meaningful pressure on the tyre. It’d be interesting to see if the Rimpact (which he reckons are bit more compliant) would be the same on his rims.
We were talking about this last night; is it better to have a cushcore type setup that might be a PITA to remove on the trail against a far greater chance of not needing too because it’s protected your rims and tyres. I’m going for the latter, but time will tell.
Posted : 06/01/2019 11:20 am
How's the testing going?
Posted : 11/01/2019 4:30 pm
I've only managed 1 short night ride so far and also changed my front tyre at the same time as installing the Rimpacts. New front tyre + lower pressures = loads of grip. I have more peace of mind now about if I puncture on a descent (which has happened twice) that my rim will be ok when I stop at the bottom. I will update when I have spent more time on my bike.
Posted : 12/01/2019 12:05 am
Great thanks, I’m debating on ARD or Rimpact, dunno which one to get..
Posted : 13/01/2019 8:52 am
 Alex
Four rides on the Rimpact now. Around 150km. Two in the FoD, 1 Malverns, 1 Brechfa as posted previously. Malverns is rocky in places and the wheels feel indestructible (famous last words). As I said before, it could be placebo, it could be that it’s a new front tyre, it could be great conditions or a combination of all those things, but I do feel I can notice something.
I’ve not smashed a wheel yet where I’d expect to get a puncture so I ca’t comment on that. But they do seem very ‘supportive’. And Matt from Rimpact is very helpful if you’ve got any questions.
So far, fit and forget, gives me some ‘insurance’ for rubbish lines and *might* offer a bit of a performance upgrade.
Posted : 13/01/2019 9:51 am
 Alex
Oh I’ve settled on 19psi front, 21 rear so down 2 PSI on my previous tyres. Again tho, not likely to make any difference, but this feels like the sweet spot.
Posted : 13/01/2019 9:53 am
Did people find these Rimpact inserts hard to fit with tough tyres?
Having a 'mare trying to get a Supergravity Hans Dampf on a 30mm internal rim with one.
Posted : 24/01/2019 9:47 pm
I can see how it could be tough.
It Was fairly easy getting a 2.5 exo aggressor on 35mm rim
Posted : 25/01/2019 12:55 am
But I imagine the narrower the rim and less flexible the tyre the harder it would be.
As usual getting the tyre well under the insert and into the well if the rim made the difference for me.
Posted : 25/01/2019 12:57 am
No more difficult than it it is without it. My tire/rim combo is a tight fit with Rimpact or without.
Posted : 25/01/2019 5:32 pm
Well it's done now, definitely much harder than tyre alone though.
Had to resort to the trusty metal lever, in direct contravention of the instructions - but I was careful so it should be OK.
Looking forward to testing tomorrow.
Posted : 26/01/2019 1:54 pm
I agree about the damped feel, and mine took some of Hebden's rockiest tracks in its stride. I might need to reduce pressure further and even twiddle with the shock settings a bit.
Your bike looks a right bruiser!
Posted : 05/02/2019 4:26 pm
I meant it looks like it's ready to do some damage, but it doesn't look light either TBF!
Posted : 05/02/2019 4:34 pm
