Not enough clearanc...
[Closed] Not enough clearance for a Mucky Nutz - Suggestions.
[#4603146]
I am running a 2.25 Ardent, and a 2.0 Mucky Nutz mud guard. There always seem to be something rubbing.
Any suggestions?
Posted : 28/11/2012 5:08 pm
crud catcher?
Posted : 28/11/2012 5:09 pm
A Crud Gonzo?
Works well for me on an E150SL fork with not a massive amount of clearance! With a Crud Catcher as well, I should add.
Posted : 28/11/2012 5:11 pm
Crudcatcher + Neoguard?
Big fat THE fender in the fork-crown. Moto-styleeee for maximum coverage.
Posted : 28/11/2012 5:12 pm
Inner tube based/bodged 'beef curtain'?
Posted : 28/11/2012 5:23 pm
Depends which direction you want to go. If you want more mud protection, then get a Shockboard or something similiar (I recommend the shockboard, the mounting hardware's gash but cableties fix it, and it performs well enough to forgive that.
If you don't mind less, then a RRP/inner tube. Might want to complement that with a crudcatcher too. Watch your fork seals- this sort of guard can cause more mud to gather round them.
If you want something that looks incredibly awful yet also doens't work very well, then the Crudcatcher + Crudcatcher Ridiculous Spy Vs Spy Nose Thing will work less well than a Shockboard, cost more, and weigh more.
Think that's all the bases covered.
Posted : 28/11/2012 5:31 pm
Are you sure it's fitted properly, I don't get any rub even running a 2.4 in Magura forks which aren't the best for clearance. It's only wafer thin after all!
Posted : 28/11/2012 6:13 pm
 br
Reba forks by any chance?
Posted : 28/11/2012 6:26 pm
Recons actually
Posted : 28/11/2012 7:36 pm
 grum
I have 2.5 tyres with mine and clearance seems fine (Fox 36 forks).
Posted : 28/11/2012 7:40 pm
I had no clearance for a muckynutz with a set of 29er Recon's running HansDampfs, a crudcatcher isnt enough so i'm going to augment it with a neoguard and hope for the best.
Posted : 28/11/2012 8:35 pm
Rockshox don't seem to have masses of clearance for a mucky nutz...
There's virtually no clearance on my Rebas....I keep meaning to make my own version that mounts on top of the brace, rather than under it.
Posted : 28/11/2012 10:03 pm
Neoguard + crud catcher
Posted : 28/11/2012 10:19 pm
Earphones!!
Posted : 28/11/2012 10:26 pm
I tried a 2.2 Rubber Queen on my Reba's - they rubbed the brace, so swapped em for an Ardent with a mucky nutz guard, was fine until it got muddy when it started rubbing & wouldn't stop... so I'm now running with nothing...just have to keep my eyes closed.
Posted : 28/11/2012 10:40 pm
