My shock never used to leave any oil residue on the damper shaft at all. It was always clean and dry when riding. Now after I have serviced it - new seals, grease, oil etc I get a build up of dirt etc on the travel O ring and at the end of the damper shaft. The dust is attracted by the oil/grease residue that comes through the seals. Is this normal? Its not losing air at all, just a weep of oil. Its been 4 rides since the service and there seems to be no end it to.
A - either this is normal and it should have been doing this all the time
or
B - Its not .
Surely its not good for the shaft to have have fine dirt on it as it will act like sand paper??
IME this is pretty normal and it stops after a 'while'. Had it with a new monarch and also following DIY air can seal service.
I’ve heard mixed opinions on this. But I’ve often had this issue if I’ve put in a little too much grease. Leaks out for 5 or so rides and then goes back to normal.
