Noob Maxle question
[Closed] Noob Maxle question
4 Users
I just bought an '08 Cube Fritzz frame with rear Maxle. What is the diameter of a Maxle? a quick google says it's probably 12mm, but the previous owner mentioned something about a 10mm hub 'working fine'. Am I right in assuming this is 2 seperate things (i.e. 10mm bolt-thru will not take a Maxle)?
Posted : 28/06/2010 7:36 pm
Rear Maxle is 12mm.
Posted : 28/06/2010 7:46 pm
12mm
this is the [url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=44142 ]QR[/url] and it answers your question.
not cheap I am afraid.
Posted : 28/06/2010 7:48 pm
Thanks (like an idiot I checked on CRC, but missed the bit about 12mm). Maxle came with the frame 🙂 So I guess I only need to fork out for a 12mm adapter.
Posted : 28/06/2010 7:55 pm
this might depress you warcow, but hopefully as you will see from my last post there is a solution.
http://www.singletrackworld.com/forum/topic/hope-12mm-rear-axle-snapped
Posted : 30/06/2010 6:15 am
MadBillMcMad - Member
That only relates to the maxle lite rather than the maxle, doesn't it?
Posted : 30/06/2010 7:06 am
retro83,
correct
Posted : 30/06/2010 9:17 am
