nobby nic tubeless ...
[Closed] nobby nic tubeless ready 26" pressures?
whats a good pressure for a nobby nic tubeless ready (11st rider) rigid HT.
I always run them quite high but think a lower psi might help with comfort being rigid
cheers
Posted : 27/04/2013 6:31 pm
 br
25psi
Posted : 27/04/2013 6:34 pm
front & rear?
I've been running around 40rear & 35front ๐Ÿ˜ฏ
Posted : 27/04/2013 6:35 pm
That is quite high for tubeless. For me around 28 seems to be the sweet spot - find them a bit 'squirmy' lower than that, especially when it's wet. I'm about a stone heavier tho.
Posted : 27/04/2013 6:38 pm
28 front & back?
riding around malham tarn 25m race
Posted : 27/04/2013 6:41 pm
It depends on conditions. If wet I'll run 28 front and back. Dry 28 front 25 back. Might seem small but I can definitely feel the difference.
I used to run these - I now use high rollers @ 25 all year round
Posted : 27/04/2013 6:44 pm
 mokl
I run one on the front, weigh 11 stone and inflate it to approx 22 psi. Ralph at the back I run at around 25 psi. On harder surfaces I can feel them squirm a bit leaning into fast corners so occasionally run them a bit firmer depending on where I'm riding.
Posted : 27/04/2013 7:30 pm
