The 332 was missing from their stand so I assume that's going 27.5
If Orange is replacing 26" range with 27.5". How come the new Alpine is 26"?
You live 5 miles away, and you're oblivious to their innovations
You can't be oblivious to the non-existent mboy
Point them out though, go for it!
I think you're right, I can't see them turning the 322 27.5", unless results show that DH bikes work better that way - they didn't at Fort Bill.
I also think it was a very sensible idea to leave the Alpine 26" as it'll no doubt be ridden through much more technical terrain. I've got a 26" five, and I having ridden a 29er, I can see how a 27.5" would be beneficial for a trails rider(29 felt too "long", 26 felt a little less fast (albeit in straight lines afterwards) ), however, for more DH / AM trails, I would definitely prefer 26".
It took them forever to get the 322 to work, I don't think they'll be charging into replacing or seriously revising it.
I recon by the time Eurobike comes around the Alpine will be 650b.
Personally, I think you have to respect any company that shuns 'innovation for the sake of it' for 'innovation only when it gives a real benefit'
I think we HAVE actually seen this in the sport in recent years - to pick a few: 135 rear bolt through is a real benefit (142 less so) 31.8 bars were a real improvement too, taper headsets you could argue either way, but I'd fall on the innovation side.
Orange have kept up with these as they have arrived, but its unfair to criticise them for failing to innovate when the five has been damn close to perfection for a lot of years - anything else they had done to it in that time would have been change for the sake of change (and marketing)
650? Well, I think that like Santa Cruz, they're stuck between a rock and a hard place.
I know that established wheel companies are somewhat 'meh' over it - like I say, where's the real benefit?
@MoseyMTB the overall width of 142 vs 135 axes is the same, the difference is 142 rear ends have 3.5mm notches on the dropouts to make fitting the rear wheel a bit easier. the whole its stiffer because its wider is just more marketing bull.
142's actually a decent standard, it's really just a correction for 135x12, all about making the wheel easier to fit. Shame they didn't get it right first time to be honest but it's kind of a no-brainer to switch now and since it was mostly quality wheelsets that caught onto 12mm, they're mostly adaptable too.
It [i]could[/i] be stiffer, in theory, by keying in the ends that bit more. But call me skeptical, even if there is a difference I bet you can't feel it (but you can imagine extra stiffness, if you paid money for it 😉 )
ah, cheers for that lads. I have a 2012 that i absolutely love. The tapered headtube and maxle rear end but the benefit of easier fitting of the 142 does make sense. It is a pain in the ..... fitting the rear 135 maxle quickly.
I would be interested if i could stick the new swing arm on the last front end though.
Despite years of "evolution", they are still making frames very close to the original 5" Patriot.
Combined with some 140mm forks, my ancient Patriot LT (2000) rides very similar to a 'modern' Five.
Hats off to them for getting it pretty much spot on years ago!
650 five will rip, 67 degree head angle on it and slightly larger wheels, slicker fitter and quicker, providing the overall weights of these 650 bikes remain reasonable.
All the major manufacturers will go 650 within 3-5 years.
Always staggers me how I manage to ride a 26er at all these days, let alone keep up on the trails with the new wheel sizes!!!
hold the phone, IIRthemarketingbullshitC tapered was much lighter to produce than a 1.5" headtube.Having a tapered steerer adds lots of weight. It is much lighter to make an 1.5" steerer
1.5 does mean you can fit any spurious fork that's on sale at the end of year, so that's a win in my book.
650b is hardly "big wheels" is it? more of a [s]marketing opportunity[/s] new standard.it will be interesting to see how many
big wheels = pointless
orange = awesome
convert one way or the other
noisy tho, filing cabinet full of spanners on the way down and a running commentary of "shit, bobby, single pivot [b]bollocks![/b]" from you everytime the trail points slightly upwards.Yes it is simplistic, Yes it is ugly but boy does it ride pretty
It is? Admittedly I probably can't change wheels at F1 pit stop speed, but I've never noticed a problem with the current maxle setup
thought wider wheels was for less/more* dish so stronger, or have I not been reading the marketing properly? 😉142's actually a decent standard, it's really just a correction for 135x12, all about making the wheel easier to fit.
*can't remember the specifics of "dish"
Did they? they went through a few linkage based designs, before stamping a hole in the DT and making something that looked like a 224 with a hole in the DT.
Change for 650B would just be a slight tweak to the geometry of the frame and swingarm (assuming there's clearance under the saddle).
thought wider wheels was for less/more* dish so stronger, or have I not been reading the marketing properly?*can't remember the specifics of "dish"
165mm was dishless (actualy they weren't, the flanges were wider, but the wheels were still dished), 150mm was a comprimise. Neither really wored out though as the chainstays got so wide you couldnt fit a chain device or your feet caught the swingarm every time you pedaled.
Not for a carbon bike, as obviously there is less material, but apparently they are the way Orange makes 'em. They have this little bit of metal between the taper on the headtube, and the downtube, looks like that has been omitted now the heatube is straight.
