New frame time,need...
[Closed] New frame time,need a bit of help
I'm looking to buy a new /second hand frame. Frames I'm considering are SC 5010 alu, Transition scout or Nukeproof TR, etc As you can see a theme is occurring in that I'm after a short travel rear and upto 140mm on the front.
I currently have a 2011 Turner 5 spot with with 160mm up front. I know I could just drop the fork length how ever i fancy a change.
All the above a 650b and there would have to be a transition period where I'm swapping bits over, so maybe something that would ride OK for a while as a 26 inch wheel setup.
Or am i missing something in the 26 inch wheel size that would be of a similar style. The SC trc comes to mind but are hard to come by. If it helps i usually ride a medium sized frame.
Posted : 08/08/2015 3:23 pm
Transition bandit.
Posted : 08/08/2015 3:24 pm
