New fork steerer, h...
[Closed] New fork steerer, how & where?
What is the best technique to change an alu fork steerer which is too short for a new frame? Where could I get a new one from? The fork is a Marzocchi Bomber RC3 '09, 1 1/8".
Posted : 03/07/2010 6:24 am
You can't, it's bonded in. You'd have to get a new steerer, crown and stanchion assembly from the importers. Windwave I believe. Or sell the fork and buy one with the right length.
Posted : 03/07/2010 6:26 am
I was thinking about this the other day, there must be a better way of fitting them, ie , threads but then again, who wants a steerer to unscrew...
Posted : 03/07/2010 6:42 am
You obviously weren't here a few years ago for the "kettle of boiling water and curbstone" trick.
Posted : 03/07/2010 7:40 am
Brant, that rings a bell, could you remind the procedure, please?
Posted : 03/07/2010 8:12 am
Essentially, the steerers are press-fit into the crown using some sort of "cryo" process. Cooling by a few degrees K in your freezer isn't anywhere near the change in expansion you can get by increasing the temperature with boiling water.
So - couple of kettles of boiling water over many things (siezed crank arms, or in this case a fork crown), and a bit of a tap, and things come to bits easily.
To install, more hot water, and bang it back in.
Of course non of this is officially recommended 🙂
Posted : 03/07/2010 8:41 am
Windwave will fit new steerers in 'zocchi forks. I have had it done twice. around £40 depending on the type of steerer
Zocchi are not bonded in - they are a press fit.
Posted : 03/07/2010 8:42 am
