New BFe build
[Closed] New BFe build
Finally got around to finishing the new BFe build and took it for a short raz aroud! Cannot wait to get stuck in properly. It's mad fun to throw around, bombproof and although I haven't weighed it yet - definitely not a heffer.
Posted : 29/08/2013 10:31 pm
Lovely. Just needs a dropper post now. You can't have a BFe, unless it's a little DJ/4X bike, without a dropper post.
Posted : 29/08/2013 10:32 pm
Nice! I reckon 26.5-27lb for that build, if those are 32's ๐Ÿ˜€
Posted : 29/08/2013 10:57 pm
Mmm, good job. 27.5lb is my guess.
Posted : 29/08/2013 11:11 pm
Very nice ... the bike just wants to get up and go
Posted : 29/08/2013 11:13 pm
Are you mad? Those cranks must weigh 2lbs and those pedals another 1lb. I can't see that dropping below 29lbs.
Posted : 29/08/2013 11:19 pm
 timc
28.5 my guess
Posted : 29/08/2013 11:34 pm
Yeah 32's on there. Going to have to deliver on the weight now!
Posted : 30/08/2013 8:43 am
Oooooh I reckon 26.74.
Either that or 27.12 depending on whether that rear tyre is folding or not.
Posted : 30/08/2013 8:52 am
Very nice indeed! ๐Ÿ˜€ what travel are you running? Also- ignore the dropper post comments, it's perfect as it is!
Posted : 30/08/2013 8:53 am
Wow! Very nice, I like all of the white parts, you just need some white Oakleys now and you'll look absolutely great.
Make sure you clean the white parts regularly, otherwise your bike will look loads worse than it does now.
Posted : 30/08/2013 9:11 am
140mm floats. Thought about the talas but after a test ride on some I took the plunge on the floats.
Came in at 28.1lbs! Wheel set is quite beefy as is chainset so can see why.
Yeah white bits are going to take some maintenance.
Posted : 30/08/2013 1:23 pm
Going in on trend, thats either 27.5lb or 29lb. now way it'll be 26lb, its not retro enough.
Posted : 30/08/2013 1:34 pm
