nerdy fork setup q...
[Closed] nerdy fork setup question for PA hardtail.
4 Users
 GEDA
I have a PA which is meant to run with 130mm forks. I got a nice pair of 150mm Marzocchi 2005 Z1's.
As the only thing that separates the 130mm and the 150mm forks seems to be a preload adjuster of 20mm what are the opinions of just running the fork with 20mm more sag? then you will get the best of other worlds surely or am I missing something?
Posted : 06/02/2009 11:16 am
To run it with 20mm more sag will mean having a very soft spring-rate in the fork, so you'll go through the travel quicker.
Posted : 06/02/2009 11:49 am
Geda, the Marzocchi forks tended to be longer from axle to crown than equivalent travel forks from other manufacturers but I can't remember which year they corrected this (or indeed if they ever did).
In general, I tend to recommend 130mm travel forks for the PA as that's what I designed the geometry around.
However, I think pretty much every fork has been used on a Prince Albert at some point since they first came out in 2004 (I remember chuckling when I saw one with a Junior T on it), so if the 150mm Z1 floats your boat just try it. I doubt it will snap your headtube off. Nobody's done that to a PA yet. Just don't come crying to me if you ride head on into a tree and the top/down tubes crease 😉
Posted : 06/02/2009 11:51 am
 GEDA
Cheers, I will give it a go. I do not ride it hard enough to do myself real damage.
Posted : 06/02/2009 12:41 pm
The z1's @ 130mm have something like a 518mm a2c height, which is about the same as pikes @ 140mm and probably similar to a Lyrik @ 130mm.
I prefer my Dialled Alpine @ 130mm for the general riding I do, seems to make it more responsive.
Posted : 06/02/2009 1:08 pm
