My Truvativ-adapted...
[Closed] My Truvativ-adapted Hope ceramic BB has seized up
The non-drive side with the adaptors fitted has virtually stopped spinning. Has this happened to anyone else? I called Hope and they said return it, there's not much you can do to sort it. Strikes me that the adaptor system could be flawed?
Posted : 28/05/2010 1:46 pm
Been running my Hope SS on a set of Noirs for a year, and the BB saw service on shimano cranks previously.
Removed the seals and checked/regreased last week, and other than a tiny bit of surface corrosion on the actual crank axle, they were absolutely spot on still. No issue for me.
Posted : 28/05/2010 1:58 pm
Swift, how did you remove the Truvativ adaptors to service the non-drive side? You can't remove the lip seal or get to the bearing with the adaptors fitted.
Posted : 28/05/2010 2:06 pm
With a lot of patience, and an old bearing removal tool, eventually popped it off. Probably not for the faint hearted though.
Unless it seizes also, i wont do it again, seeing how good it was this time.
Posted : 28/05/2010 2:14 pm
Cheers. It'll be back in the post to Hope I think, that's the best bet.
Posted : 28/05/2010 2:16 pm
