noticed this morning whilst honking up some climbs that my '09 Revelations were squeeking. Seems like the seal/wiper on the left stanchion. Forks are working fine apart from this. Is it of case that they need a strip down/new seals or can I put some sort of lube on the stanchions, if so what fork lube is good?
Cheers all.
could be the bath in the lowers or the air spring, it's all easy to re-lube but to do the air spring properly you'll need circlip pliers
Sound like you need to do a lowers service.
[i]Sound like you need to do a lowers service.[/i]
+ 1. If it's dry under the seals/dust wipers then its only a matter of time before you going to start causing some damage.
Lowers service is easy enough and you don't necessarily have to replace the seals/wipers. Just need some oil and some basic tools. RockShox site is good for guides but help available on here
