Monarch RT3 problem
[Closed] Monarch RT3 problem
Hi, after a few weeks off the bike I now have an issue with my 7 month old Monarch RT3.
I have searched the issue without finding anything the same.
When i got my bike out this morning, I noticed a lack of pro pedal and lockout. Then i checked the sag which was beyond the 40% mark.
I checked the air, 180psi, pumped it to 200psi, the issue remained.
Released all the air and pumped back up to 200 psi, sag now 20% with pro pedal and lockout working. A few bounces of the bike later issue has occurred again. Checked the air pressure 190psi (perhaps lost 10psi when connecting shock pump?).
Repeated the above, still the same, decided to look at it another day.
Is there anything else I could try or is it a warranty job?
Appreciate any help or advice.
Posted : 18/12/2016 8:27 pm
When mine did similar the seals had gone and let in a load of water after 6 months
warranty sorted it, but you could probably replace seals yourself
Posted : 18/12/2016 9:12 pm
Seal kit service should sort that. Loads of vids show you how on youtube
Posted : 18/12/2016 9:33 pm
