Anyone know if mmo's will work with Garmin or will they need to be converted
cheers
If not try this to convert the file...
[url= http://www.gpsbabel.org/index.html ]http://www.gpsbabel.org/index.html[/url]
memory map should be able to convert it. Export it to device if you have the device connected and detected on your PC?
Thanks for the posts but having trouble getting theses on my Garmin 605! Do they need to be TCX files or GPX
cheers
NEED to be converted - if you have MM right click the route when loaded then save as then select GPX.
I use TCX convertor for GPX to TCX to convert routes to courses.
http://www.teambikeolympo.it/TCXConverter/TeamBikeOlympo_-_TCX_Converter/DOWNLOADS.html
What file are you trying to convert - I have MM mail me?
Or download a trial of MM and convert it using the demo?
ok cool cheers foxy, ive got them from mmo to gpx, now will try that program!
I often convert GPX to TCX course then upload it to the Course folder then you can follow the route.
cheers Foxy all sorted!
