ProblemSolvers only seem to do a right hand 1x adaptor and they seem to be out of stock everywhere
Are there any other options?
Wolf Tooth do them.
Wolf Tooth don't do anything to connect shimano shifters to SRAM brakes...
ShiftMount naming convention is [shifter type - brake type]
MM-ISII is for a SRAM Matchmaker shifter mounting to a Shimano I-Spec II brake
MM-ISEV is for a SRAM Matchmaker shifter mounting to a Shimano I-Spec EV brake
ISEV-ISB is for a Shimano I-Spec EV shifter mounting to a Shimano I-Spec B brake
ISEV-ISII is for a Shimano I-Spec EV shifter mounting to a Shimano I-Spec II brake
MM-MAG is for a SRAM Matchmaker shifter mounting to a Magura brake
There's lots on ebay.
Also trickstuff used to do versions
https://www.bike-components.de/en/Problem-Solvers/MisMatch-2-2-Adapter-p57137/
There you go, both sides.
Mine's a pint of best.
Ouch - £50 - cheaper to buy a Bonty dropper lever that will fit to the SRAM brakes directly!
So I could buy the Bontrgaer lever to replace the Brand X lever that doesn’t fit my Sram RSC’s and keep the Brand X one for when I get another drop on the hardtail which has shimano brakes?
Bump.
Brand X one? What exactly are you trying to fit to the SRAM brakes?
Paul - the newer Line Elite lever will mount directly to SRAM matchmaker thing that comes with retail brakes (and comes with adaptor for shimano)
Thanks @Benpinnick - yep BrandX dropper on the left wanting to fit to left sram brake lever.
On the other bike it’ll be the same onto Deore brake.
Paul you have 2 options likely. 1 your lever is the mmx style which will fit direct to a sram MMX mount if you add that to your brakes, or you have the other type of Tranzx remote which will need the sram MMx adaptor for it... Which you may or may not be able to find.
Thanks Ben
I’ll have a look about and work out which Ascend lever I’ve got.
