mtb tubeless i can do - gravel/road struggle with the pressure and glass cuts
running 35mm swalbe G ones with stans generally good but this week had a sidewall cut (3mm?) which puked sealant all over the garage floor and I stuffed a furry thing (forget brand) to help it seal and it worked
? no idea how much sealant in tyre now (and not for first time) so do Milkit or similar valves work? is it easy to find out if any sealant in their or do I just fill up on assumption not much left
?2 does anyone carry a small bottle of sealant to add after getting sprayed? if so does is keep or go solid and waste of time when needed....any bottle suggestions...some of daughters cake icing stuff looks ok
Take wheel off bike, put it down for 10 minutes, pick up carefully, keeping the bottom down, shake wheel next to your ear.
If you can still hear it sloshing about you are golden.
