Mavic crossmax slr ...
[Closed] Mavic crossmax slr help please!!
2 Users
Hey my mate has just purchased a pair of 2011 in centrelock. Fitted the rear disc with no problem but the shimano tool does not fit the front. Is this due to the interchangable front hub conversion as you can either run 9mm axle (current set-up) or have the option of running 15mm pull through axle? I'd appricated any help and the tool used was the tl10 but there is a tl15 but unsure of the difference it would make to be honest. Your comments please.
Posted : 10/02/2011 7:51 pm
Just need to pull out the centre collar
pictorial instructions here:
http://forums.mtbr.com/showthread.php?t=583410
Posted : 10/02/2011 7:56 pm
