marzocchi bomber ba...
[Closed] marzocchi bomber bam z3 rebuild help!!!
I have been given a set of these forks and after respraying them need to now rebuild them. I'm aware that I can used motor oil with them but a little unsure as to how much I need t actually put in, if anyone has a rough idea that would be great.
The ones I've got are the 120mm version and I weight around 80kg.
I've had a google search and not much comes up so any input would be great thanks.
Posted : 22/01/2013 9:27 pm
Notmotor oil
Motorbike fork oil 7.5 weight
Compress fork and remove springs and fill till 55-75mm from the top
Posted : 22/01/2013 9:32 pm
Thanks for that trail rat, I'm guessing you have done a few pairs of these?
Posted : 22/01/2013 9:38 pm
Over the years and from z1 to z5
Great forks
Posted : 22/01/2013 9:42 pm
Mine are the air version does that change anything?
Posted : 22/01/2013 9:45 pm
Now that you didnt say.
Flylight air ? Blue / dark purple ?
What year - there should be a date stamp on the inside of one of the legs
Posted : 22/01/2013 9:51 pm
