magura Julie brake ...
[Closed] magura Julie brake lever - is upside down OK ?
a bit of a cock up on the orderring front.
I ordered a left hand brake by mistake and did not realise until I had cut open and mounted the disk and caliper.
The lever fits OK with the gear shifter.
So the question is, 'Is the brake lever OK upside down' ?
Posted : 18/08/2010 9:47 am
I reckon with the lever upside down you will end up pumping air into the brake from the top of the resevoir. However, this will depend on the design of the lever and the resevoir.
Just a thought......
Posted : 18/08/2010 12:11 pm
sadly I think you are correct splash-man.
anyone want a left hand 180mm Magura Julie HP ?
Posted : 18/08/2010 2:25 pm
