Hi.
Does anyone know where I can source the foam rings (that sit under the wiper seals) from a UK supplier. I've Goggled it and typically - Magura no longer supply them and the only other places I can find are over the Channel and want over 8 Euros postage (which is twice the price of the rings !!).
Are any rings from/for other 32mm forks known to definitely fit ?
Michael
I'm pretty sure I used fox 32mm foam rings and seals for that matter and it worked fine. On my old menjas.
Magura stopped using them and went from a oil bath to a grease system.
Why? who knows?
so you can't get them, nor could you get the special grease they stated you must use.
Anyway a session going through the spares parts J-Tech (thanks Jim) and as Craggyjim says Fox foam ring and Seals work.
Job done.
