Lyriks and Pro 2 hu...
[Closed] Lyriks and Pro 2 hub - can't get my maxle in?????
I've got a new wheel with pro 2 hub but i can't get the maxle through the far side fork leg. If i take the wheel out it goes through the wheel on it's own fine and it goes through the fork fine on its own but not together?
It all seems lined up and i've tried waggling it a bit but it's not even just tight, it's no where near.
anyone had similar problems?
Posted : 25/01/2011 10:13 am
Could be that the bearings in the hub aren't seated quite right?
Or try loosening off the other side of the maxle.
Posted : 25/01/2011 10:24 am
thanks, I'll check the bearings, tried loosening the maxle
Posted : 25/01/2011 10:48 am
ive had very similar with my maxle lite equipped sektor. i got some wet and dry sandpaper and sanded down the inside of the adapters untill the maxle fitted. works fine now.
also grease the shaft ๐Ÿ˜†
Posted : 25/01/2011 11:20 am
ta, i'll give that a go too
Posted : 25/01/2011 2:38 pm
