Lyrik Solo Air (160...
[Closed] Lyrik Solo Air (160mm) - can you reduce the travel to 140mm internally?
My I have a lot of questions tonight...
Anyhoo, a bit of a google fails to turn up an easily found answer to this one, so I turn to the STW hive mind for enlightenment! ๐Ÿ™‚
So... can it be done? If so, how?
thanks ๐Ÿ™‚
Posted : 15/10/2010 7:34 pm
Yes you will need a all travel spacer kit from rockshox I know fishers are out of stock ATM untill November but I think tf have them can't remeber the part # off my head. It will fit on the left hand leg negative spring like on a fox fork.
Posted : 15/10/2010 7:47 pm
eggcellent... I can see a plan coming together ๐Ÿ™‚
Posted : 15/10/2010 7:58 pm
You dont need a spacer, I used a stack of M10 2mm thick nylon washers. Easy to source on fleabay, work perfectly and give you more scope for adjustment.
Posted : 15/10/2010 9:08 pm
