Lumicycle HID cutte...
[Closed] Lumicycle HID cutter LED conversion, tell me how!
I want to convert a failed Lumi HID to a cutter LED package
anyone got useful hints and tips or links to threads please
if anyone has one or two kits in country let me know as well
Posted : 26/04/2009 9:12 am
link to more piccies here
[url] http://www.flickr.com/photos/17059060@N00/sets/72157605077985739/ [/url]
anymore info needed just let me know
Posted : 26/04/2009 10:13 am
Bit of a hijack:
I've got a budget kit, which Cutter sent with some sort of bonus circuitry board, so it's going to be a struggle to fit into the older Lumi Halogen can I'm using. Will have to file it down and go without much of a heat sink - unless anyone has any ideas??
[url= http://www.cutter.com.au/proddetail.php?prod=cut790 ]This one[/url]
Posted : 26/04/2009 10:22 am
I'll have a measure later and see if it will fit into the HID Housing.
Posted : 26/04/2009 10:29 am
You can always put the circuit board in the battery housing instead of the lamp head.
what are options for the heatsink?
Posted : 26/04/2009 10:30 am
Heatsink is pointless in a sealed container. Just make sure you get a good thermal connection to the casing (which will lose the heat to the environment)
Posted : 26/04/2009 10:35 am
I bought some ally bar off ebay i'll find the size later but it was about 0.1mm less than the internal size of the HID housing assembled using heattransfer paste and it works a treat.
Higgo is spot on. The key is getting the heat to the outside of the casing.
Posted : 26/04/2009 10:42 am
I also bought ally bar & made a heat transfer 'slug'
Not a Lumi housing but same principle, slug should be a tight fit in the housing & smeared with heat transfer compound - when assembled, the housing should get hot fairly quick if the heat is transfering well.
Posted : 26/04/2009 10:49 am
