low stack height st...
[Closed] low stack height stem or headset?
Here goes...
Bought a new frame and headset and transfered my old forks over. There "should" have been no problems, head tubes were the same length including the headset spacer I was using. However, it's a bit short! 😳 The stem will clamp up ok but I'd like a bit more length (oohh er missus). Anyone recommend a low stack stem or headset? headset needs to be an old skool external one. Current set up is FSA headset and raceface stem.
Posted : 06/04/2011 1:23 pm
Crank Bros are the load stack headset of choice currently I think.
Posted : 06/04/2011 1:24 pm
Crank Bros? Cool. I may be showing my ignorance here, but are all stem clamps the same height?
Posted : 06/04/2011 1:28 pm
 nuke
How big is the gap between top of steerer and top of stem?
[i]are all stem clamps the same height[/i]
No. Although generally most are around 40mm. Some FSA stems are 35mm
Posted : 06/04/2011 1:30 pm
A shorter stem would be an easier swap, as it'll save swapping headsets over 😕 FSA you say...
the gaps 8 or 9 mm I suppose. It'll clamp tight, but the top bolt is tighter than the botton one (if that makes any sense)
Posted : 06/04/2011 1:31 pm
 nuke
[i]FSA you say...[/i]
Yes but not all of them so check
[i]the gaps 8 or 9 mm I suppose. [/i]
Thomson, for example, advise 3mm although plenty of people will say that they've ridden around with more than that, are still alive and have their own teeth
Posted : 06/04/2011 1:33 pm
 R979
Spank do the spike stem:
http://spank-ind.com/index.php?a=info&do=pro&id=33&tid=1
About half the stack height of a normal two-bolt stem. Short though...
Posted : 06/04/2011 1:35 pm
I had this problem with my 29er and a second hand fork that was marginal for length plus wanting to get the front end lower.
I've gone for a CrankBros iodine headset (20.5mm - considerably shorter than an FSA XL2 which is 27.5) and a FSA OS-115 stem (35mm stack which is shorter than most others which are usually 40-45mm).
 nuke
The thing about the CB headset is that it is expensive, not very durable and gets surface rust
(Current owner of CB headset 🙁 )
Posted : 06/04/2011 1:40 pm
Mine was £35. I would have been wary but I reckon with a 5 year warranty I can live with it.
Posted : 06/04/2011 1:41 pm
This is the spank spike stem -> http://www.pinkbike.com/photo/5287747/
50mm rear, 0 deg, VERY low stack (with only one bolt clamped)
Sunline stems have a low stack height
Posted : 06/04/2011 1:59 pm
 5lab
kore do a stem as well, and its cheap. Called the B1B
Posted : 06/04/2011 2:08 pm
appologies for the late reply, couldn't get on line at home...
Thanks for the help, certainly a few options! I'll probably go for the Sunline stem (yes, I'm a tart), the Spank's a bit [u]too[/u] short although it does look nice... and the headsets brand spanky new so don't want to take it off if I can avoid it.
Cheers! 😀
Posted : 07/04/2011 11:41 am
I used a Sunline V1 All Mountain stem when I had a steerer length issue. Worked a treat as it was almost 10mm lower than the one it replaced.
Posted : 07/04/2011 12:17 pm
That's what I've gone for, bought from all terrain cycles as they were cheapest.
Posted : 07/04/2011 12:35 pm
I ran a slightly short steerer for a while on my Whyte 19 - probably 7-8mm showing inside my Thomson stem.
Never slipped, never caused me any issues, I still have my front teeth - even occasionally took off!
I'd clamp it up and see if you can move the stem with the wheel between your knees - pretty sure it will bend the wheel before slipping!
Posted : 07/04/2011 12:49 pm
it feels tight, but does creak a bit... the bike does get off the ground fairly regularly, and it's not an expensive stem on there anyway. I'd rather part with the cash then spoil my, er, good looks. 😯
Posted : 07/04/2011 1:13 pm
If it's creaking and inexpensive I'd change it for sure.
Posted : 07/04/2011 4:12 pm
Erm, daft question, presume you don't have the old headset off your old frame you could use - surely if you've got that (or a direct replacement) everything will be tickety boo?
Posted : 07/04/2011 5:49 pm
I've got a FUNN Rippa stem for sale that has a 32mm stack height, not the lightest thing ever but it's a nice bit of kit. Another option is the DMR Swarm stem which has a 30mm stack height and looks pretty sweet.
Posted : 07/04/2011 5:55 pm
 ash
Ragley Stubbing
Posted : 07/04/2011 6:20 pm
