Loose grips
[Closed] Loose grips
7 Users
I washed my bike on Sunday using Muc Off and a hose (not jet wash). While fettling last night I noticed that one of the bar grips is loose and rotates around the bar. I can pull the grip off quite easily too. The bike's only a couple of months old and the grips are stock.
Can anything be done or do I need new grips?
Posted : 20/04/2010 10:39 am
Remove the old grips, clean the bars, put on new grips.
Lock on ones are good...
Posted : 20/04/2010 10:40 am
clean the inside of the grip and the bar with meths or similar solvent.
Use hairspray on the bar then quickly put the grip on and leave for 24hrs
or just buy lock-on grips which solve the problem entirely.
Posted : 20/04/2010 10:41 am
water and muck-off on the bars and under the grip - cean off with water and dry thoroughly (stick it int eh airing cupboard). The spray the bars with a bit of hairspray and put on ASAP and leave for a good few hours and you should be fine I would think 🙂
Edit: sorry repeated post 😉
Normal 'push on' grips are, and always have been, a pain in the arse. Just get rid of them and get some cheap lock-on grips. There's plenty around for under a tenner these days - On One, Halfords, Wiggle, Bontrager.
Personally I'd rather a bike was £2 cheaper and came with no grips at all, rather than fitting slide on grips....
Posted : 20/04/2010 10:46 am
I've got a nearly new pair of these you can have for £10 posted if you want? VGC, just prefer Lizard Skins Chargers
Posted : 20/04/2010 11:29 am
"Brown with flange and alloy rings"
Posted : 20/04/2010 11:33 am
Brown grips? Uhm, thanks but no thanks. I need some for a ride tomorrow anyway.
Thanks for the tips - looks like lock ons are needed.
They matched my saddle:
Posted : 20/04/2010 11:41 am
