I've found at halfords but in cages.
Surely someone sells a bag of loose ones?
What size are they if I buy from a none bike shop?
http://simplybearings.co.uk/shop/index.php?cPath=23
LBS should have them in stock I reckon.
What hub is it? I assume Shimano and googled and got this http://steveukmtb.wordpress.com/shimano-hub-overhaul-cup-and-cone/
Did you ask in halfords? last time i bought some it was from there but not on the shelves.
[url= http://www.sjscycles.co.uk/ball-bearings-dept428_pg1/?sessionid=45bcf498f5a3d719c939a194dfc8e9beace948cb ]St John St Cycles[/url]
Thanks all
Any decent LBS (and most bad ones)
The problem is, most LBSs sell Grade 1000 bearings, Weldtite for instance. In fact, asking all my local shops what grade the bearings were just got me blank looks for my troubles. Grade 1000 is great for your furniture casters, but for bikes????
It is reckoned by those in the know that Grade 100 is merely 'adequate' for bike use. Shimano apparently uses Grade 25 in their XT/XTR/Ultegra/Dura-Ace hubs, and Grade 45 elsewhere.
Unfortunatly that information would be lost on 99% of customers as well.
SJS Cycles (to name but one bike shop who knows a bearing grade from their elbow) might beg to disagree with you. ๐
What size and how many do you need? I might be able to help.
Ison distribution sells grade 25 loose balls but you have to get there stuff through a lbs
http://www.ison-distribution.com/english/product.php?part=BG2514
Are you the guy who sells clothing for the larger gentleman?
