Long shot - tapered...
[Closed] Long shot - tapered forks in a Cannondale SI headtube?
Aluminium frame. The internet tells me I need a kit of bits which I don't mind buying...
...but out of interest...
...does the lower bearing press directly into the head tube or does the kit contain an adapter?
My guess (hope) is that a 50.8 mm diameter bearing with a 40mm (1.5") hole through it sits directly in the headtube 😐
Anyone done this?
Posted : 01/06/2017 1:36 pm
Isn't this what all non-lefty cannondales do now that 1.5'' straight steerer forks are less common? Doesn't sound like a longshot, but maybe I'm missing something. I did it with my jekyll and as I recall it was just a spacer to add to the top bearing.
Shame that the 1.5 straight didn't stick as it looks miles better at the stem than 1 1/8 IMHO.
Posted : 01/06/2017 1:49 pm
Converted a Flash alloy to tapered recently, used a cannondale kp205 converter kit for about £30. It's effectively a complete new headset to fit an SI headtube & yes from memory lower bearing fits straight into frame - I did find I had to file the crown race to get it to fit as it was too tight on the fork steerer but cutting a slot in it would probably have been a better idea. Good luck
Posted : 01/06/2017 2:55 pm
many thanks
Posted : 01/06/2017 3:05 pm
