....will allow both geared and singlespeed, drop bars, discs?
Ideally cheap too. Steel preferred, but open to anything. 100/135 QR ideally.
I was looking for something along those lines a while back; on paper it'd be the Roadrat, but that has flat bars...
Yeah.. and this is to replce my old flatbar roadrat
Aren't pretty much all disc ready F&Fs (new ones anyway) thru axle now?
Planet X Kaffenback? Not sure if it has switchable dropouts though
Kaffenback has a fixed dropout
Surly Straggler or Bombtrack Arise come to mind.
Transition rapture
In my opinion, "pure" (tensioner-less) singlespeed is not worth the effort.
You open yourself to issues if the chainring is ever so slightly eccentric, need to re-tension as the chain stretches - the disc brake caliper needs to move with the wheel as well...
I currently use a Surly Singleator on one bike, previously used a Rohloff DH tensioner on another.
just put drops on your rat.
Unless you want it fixed or can't abide the look of it, a tensioner does a perfect job and gives you loads more options for frames. e.g. the steel Charge Plug frames which are cheap at the moment.
Bombtrack Arise loks promising, that's on the list
+1!
+2 if you are using disc brakes!
+3 if you are using full mudguards!
