Lightweight Hardtai...
[Closed] Lightweight Hardtail Recommendations
9 Users
 jlc
Looking at replacing an old steel 26in MTB. Looking at buying this through the cycle to work scheme as will save quite a bit of money, so slightly limited on where I can buy from and probably easier a complete bike. Looking for something that is lightweight, easy to maintain so ideally screw in bottom bracket rather than pressfit ideally, but not crucial.
Would be used for 1 to 2 hour rides from home midweek and then all day rides in the Dales at the week. Would want something that is lightweight for all the climbing but not a full on race bike if that makes sense. I am not a fast descender so something that is ok for descents and is not too tricky to handle.
Thoughts were something like a specialized chisel / trek procaliber potentially. Any recommendation would be very much appreciated. Before tax savings looking to spend most £3k, ideally less.
Posted : 27/08/2021 11:37 am
There is so much choice.
I'd go with this, the trail bike geometry will give you confidence on the descents over more XC racer geo.
https://alpkit.com/products/sonder-signal-ti-gx-eagle
Posted : 27/08/2021 12:45 pm
Unless you are out and out doing XC as wzzz says, would get something more trail / relaxed.
If you did a lightweight build, a Bird Zero 29 would be a nice option - nice bike for all round riding (and subject to component availability, sure the Bird guys could help do lighter build)
That Sonder looks nice mind.
Posted : 27/08/2021 2:52 pm
I’d be looking at this
https://alpkit.com/products/sonder-dial-xt
Sid ultimates for c £2k…have a Sonder gravel bike and they’re a very good company to deal with.
Posted : 27/08/2021 9:04 pm
I’ve been riding my Scott Scale for over 6 years now and I absolutely love it for all-day rides and shorter local rides. It’s lightweight, climbs well and is fine for descending too.
Posted : 28/08/2021 1:19 pm
You mention the Chisel.
I bought one in January, my first remotely modern bike, previous bikes being 26 inch wheeled.
It is a lovely frame, and the handling is great, lively, confident.
However, the frame deserves a much better spec. It's a really light frame but the wheels are well over 2kg, as is the pretty awful Judy fork. It was about 29lb as standard (large). I swapped wheels, tyres, fork, a few other bits and it's now about 23lb.
I considered buying frame-only but didn't like the colour options and £950 frame or £1600 full bike, the bike seemed better value.
At least in my build, it does not like to go slowly. It's not ideal for just plodding along and somehow I end up riding everything flat out and often regretting it later. It's a lot of fun, really good at technical climbs but downhill, it's still a 100mm travel hardtail, so takes some real concentration to go fast on technical trails. I'm often mentally exhausted after a couple of hours, but on the other hand it makes dull local trails so much fun.
I guess it is really an XC race bike, albeit one that, as standard, is hidden under several pounds of cheaper components.
Posted : 08/09/2021 2:42 pm
I’d be inclined to get something more trail related than the Chisel - but at the XC end of things.
Something like the Sonder Dial mentioned above perhaps is good value / should be fast.
Although personally I’d be be thinking maybe a 120mm travel fork - some quick ish tyres like Vitoria Mezcals - Reba or SID fork etc - decent groupset and brakes and lightweight wheelset.
Posted : 08/09/2021 2:57 pm
I’m potentially in the same boat, half the budget but looking at the same/similar bikes at lower spec. Hence a few suggestions on this thread:
https://singletrackworld.com/forum/topic/help-choose-mtb-for-an-old-rehab-mtber/
I’ve also looked at the Chisel, and also the Fuse (Fuse seems a more all-around capable @ 130mm) but seems it's around the same weight as my Longitude which is 29lb fitted with a rear rack and 2kg Enduro wheelset!
Seems like that’s about the weight for a £1500-£2k doitall hardtail these days? I like the idea of running a Fuse single-speed though, it looks a neat solution. Maybe have a look at the Fuse Expert? Have you looked at BMC 2021 Twostroke 01 Two? Or is that too XC? Procaliber 9.7?
Posted : 08/09/2021 7:21 pm
not sure if the Signal TI mentioned is exactly lightweight, but i can vouch it makes an amazing bike
i've built mine up as a proper trail bike, but i plan to grab a set of lightweight wheels and tyres for longer xc rides or commutes.
It's also my second sonder, first was a transmitter, so far im in awe of the company producing such good kit
Posted : 09/09/2021 9:30 am
