Let's see your...
[Closed] Let's see your modified kit
37 Users
Let's see the best and worse of your kit modifications, DIY parts, re-finished and customised stuff etc...
Anything personalised just for the sake of looking different, matching your bike better, working better or just the result of a bored evening in the garage - why, how.
A few bits I've done recently here :
Jones-style cut-down cassette carrier to use 7 9spd sprockets on my Hope SS hub - done with a file and time, did the first one with a facing tool but still needed to use the file to finish it flat. I really like this mod for using gears on the SS hub, got 12-32T with only 2 of the higher gears missed out.
[url= http://farm7.static.flickr.com/6033/6322308235_d4e4afce0d.jp g" target="_blank">http://farm7.static.flickr.com/6033/6322308235_d4e4afce0d.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/67338272@N05/6322308235/ ]7[/url] by [url= http://www.flickr.com/people/67338272@N05/ ]james-o[/url], on Flickr
Polished thumbie mount for an under-bar thumbshift - a quick easy one. Works really well with the H-bars.
[url= http://farm7.static.flickr.com/6218/6302309140_0fa877d08b.jp g" target="_blank">http://farm7.static.flickr.com/6218/6302309140_0fa877d08b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/67338272@N05/6302309140/ ]IMAG1067[/url] by [url= http://www.flickr.com/people/67338272@N05/ ]james-o[/url], on Flickr
Superstar chainkeeper - re-shaped clamp area, stripped + polished and drilled out the cage. Couldn't get a Paul Comp version easily and this was cheap.
[url= http://farm7.static.flickr.com/6120/6301781201_f1ae8150a7.jp g" target="_blank">http://farm7.static.flickr.com/6120/6301781201_f1ae8150a7.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/67338272@N05/6301781201/ ]IMAG1063[/url] by [url= http://www.flickr.com/people/67338272@N05/ ]james-o[/url], on Flickr
Now if i could find a mini-anodiser or ceramic coater..
Posted : 09/11/2011 9:38 am
I'm using a mini cassette on a Hope SS too, though I just chucked mine on the mill at work 🙂 I'm using 7 cogs off an 11-34 XT cassette, dropping the 11 and 15t. To me having a 11t and 12t always seemed pointless, and the dishless rear wheel is nice.
Apparently you can fit 8 10sp cogs on a Hope SS hub too.
Also, a Fox 180 Van 36 can be dropped in travel to as little as 135mm using a 160 Van spring and Fox spacers and no need to spring cutting.
Edit - James: Steve the anodiser is the man you want for small volume work.
Posted : 09/11/2011 9:49 am
Does manufactured count as modified? When the need arises, the occasional evening is spent in the 'shed of dread' making loud hammering noises and the occasional small puff of smoke, just like in the cartoons. Some creations that I have pictures of are:
A chain retainer made using on old derailleur, some spacers and washers:
Slotted X7 shifter levers, to remove the useless indicators and save some infinitesimally small amount of weight:
Modified Raceface seatpost clamp. I’ve seen a few like this one where either the bolt is too long or the hole too shallow. This prevents it clamping the saddle properly. The solution is to drill the hole all the way through, then anodise it green of course. I like green:
Headset top cap designed to use a countersunk bolt, much lighter because there’s no dead metal around the top of the bolt. Used with an aluminium bolt it practically disappears due to it’s own lightweightiness:
HT2 bottom bracket spacers of special thicknesses, 5mm for where two 2.5mm ones are usually required, and 1.5 & 4mm for Shimano BB’s where the 6mm bearings have been replaced with 7mm width bearings:
Singlespeed sprocket spacers. Not difficult to get hold of, but just because they are the same diameter as BB spacers and I had the metal already in the lathe:
More anodised spacers and things:
Posted : 09/11/2011 10:55 am
you knew this was coming:
[url= http://farm7.static.flickr.com/6226/6295746367_edfb947023.jp g" target="_blank">http://farm7.static.flickr.com/6226/6295746367_edfb947023.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/6295746367/ ]PA300017[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Dropouts machined by a friend of a friend to fit 10mm bolt in Hope Pro2 with increased belt length and tension
Awaits Epicyclo and Ade Ward....
Posted : 09/11/2011 11:07 am
And some earleir iterations:
Snubber Mk1:
[url= http://farm5.static.flickr.com/4086/5051882593_b93c24bba1.jp g" target="_blank">http://farm5.static.flickr.com/4086/5051882593_b93c24bba1.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5051882593/ ]DSC_0925[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Bent!
Dropout Mk1 with integrated snubber (the Gates snubber bent too) which I made on hand mill:
[url= http://farm6.static.flickr.com/5098/5505727994_f88b1c6f9e.jp g" target="_blank">http://farm6.static.flickr.com/5098/5505727994_f88b1c6f9e.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/5505727994/ ]DSC_0407[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Got around the belt climbing issue, but couldn't maintain belt tension
Posted : 09/11/2011 11:19 am
crogthomas, do you do the anodising yourself?
Posted : 09/11/2011 11:23 am
I like the dropout for belts.. would the snubber work better if it was moved forward to the are where the belt and cog mesh first?
Posted : 09/11/2011 11:25 am
I copied to the positional geometry from Gates, just put a sensible sized cross-section inplace to hold it there (and I've told Karl Nicolai his design is no good)
I think the position its in is where the belt starts to climb out when under tension, so no need to have it lower. in theory, higher tension removes the need for the snubber, but probably knackers the bearings.
Posted : 09/11/2011 11:29 am
This thread is useless without [s]pictures[/s] some cutlery/carbon fibre/epoxy-based **** whittery! 😉
Posted : 09/11/2011 11:31 am
jameso - Member
I do, but it is an almighty pain in the posteria, very tricky to get right the current, voltage, duration, acid concentration, cleaning and electrical contact. I do it because it amuses me, not because it makes sense to do so.
jameso - Member
I was thinking the same. Where it is, if the belt climbs onto the peaks of the cog, its then too late for the snubber to do anything. If it was forward of the centreline it would prevent the belt ever climbing up in the first place. See my chain retainer above as an example. It doesnt have to touch the belt, just be there to guide it onto the cog if it bounces around.
Posted : 09/11/2011 11:40 am
Quick think about this and a FBD in my head.
For the belt to be "trying" to climb the teeth, its because the tension in the upper run is enough to pull the belt all the way around the cog and there's enough slack in the bottom run to allow it to slip round. Where the belt joins the cog, the belt wil be pulled against the teeth but still into the cog, its not until you get part way round that the resultant force is in the right direction to overcome the friction against the teeth and cause the belt to slide up. Hence, the snubber roller is towards the bottom, but not AT the bottom.
I can tell the belt still occasionally rubs against it as there is a stripe on the back of the belt, and you can occasionally hear it whirring, but its only under absolute max torque on really steep slow climbs.
[i](just in case, FBD = free body diagram)[/i]
Posted : 09/11/2011 11:45 am
A perfectly good reason... : )
Posted : 09/11/2011 11:55 am
I think the belt tries to ride up because of flex in the chainstay.
That causes the rear sprocket to be pulled out of parallel with the front, so the row of belt teeth are arriving at the cog at a slight angle, and thence to catch on the top of the teeth and try to ride up.
It's why a stiff chainstay is important.
I do not use much more tension than I would with a chain.
I have not tried the new CenterTrack belts which apparently help solve this problem.
Posted : 09/11/2011 12:03 pm
Al's temple figure [img] http://t0.gstatic.com/images?q=tbn:ANd9GcRbl4vLWj6n2OZwvp8jeFxLgBFl1GCS790wZHL-jVKor74c1gNgeA [/img]
Posted : 09/11/2011 12:05 pm
The flex is certainly an issue, which is why I'm using a bolt-in hub - I've had issues with the belt slipping off the unflanged side in the past. As you say, centre-track would solve it.
I don't think its the belt teeth catching on the cog teeth though, just amount of slack in the lower run allowing the belt to be pulled round and up on the teeth when under greatest load.
Posted : 09/11/2011 12:06 pm
Does a whole bike count? (warning - E-stay 29er content)
http://www.retrobike.co.uk/forum/viewtopic.php?t=167593
Apologies about the photo size - there are some better resized pics down the bottom of the page. Anyone cleverer than me that can linky to the photos?
Posted : 09/11/2011 12:19 pm
Good work Mick! I saw that on MTBR I think.
Posted : 09/11/2011 12:24 pm
Again, waits for Ade Ward's E-stayed belt-drive 29er....
Posted : 09/11/2011 12:26 pm
Not as impressive as some of the above but I've modded the spare hole on the right hand Hope XT matchmaker to mount the poplock lever for my Rebas. Does away with the whole mount, looks neater and brings the lever into a much better position.
Posted : 09/11/2011 12:50 pm
Not so much modified but designed and had made:-
Posted : 09/11/2011 12:54 pm
Previous model is for sale on ebay at present:-
Posted : 09/11/2011 12:56 pm
Nicknoxx - what's going on there then?
Posted : 09/11/2011 12:59 pm
Nicknoxx - love that little "N" in there! 😀
Posted : 09/11/2011 1:07 pm
pics nixie??
Posted : 09/11/2011 1:15 pm
Nicknoxx, who made that for you? Nice dropout.
Here's another home-bodge, a rear cycra guard trimmed down and mounted to a fork with a bottle cork, a self-tapping screw and a zip-tie - works a lot better than the old down-tube mounted guard
[url= http://farm7.static.flickr.com/6060/6329019660_c21e29fa30.jp g" target="_blank">http://farm7.static.flickr.com/6060/6329019660_c21e29fa30.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/67338272@N05/6329019660/ ]IMAG1100[/url] by [url= http://www.flickr.com/people/67338272@N05/ ]james-o[/url], on Flickr
A broken bashguard cut down to make a mini-bash for the SS -
[url= http://farm7.static.flickr.com/6039/6329019888_a48bf549ae.jp g" target="_blank">http://farm7.static.flickr.com/6039/6329019888_a48bf549ae.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/67338272@N05/6329019888/ ]IMAG1104[/url] by [url= http://www.flickr.com/people/67338272@N05/ ]james-o[/url], on Flickr
Posted : 09/11/2011 1:33 pm
pics nixie??
Not on me, will sort some when I get home.
Posted : 09/11/2011 1:53 pm
My pals attempt at home anno.
Posted : 09/11/2011 2:14 pm
 flow
Could some one please tell me WTF is the point in having a single speed with gears? Surely you are just in denial and should go back to a proper bike?
Posted : 09/11/2011 2:45 pm
Do you mean the singlespeed hub mods above?? Surely its because you want gears but either don't need the full range, or want less dish in the rear wheel (for more strength).
Posted : 09/11/2011 2:50 pm
crogthomas, did you use a kit for doing the anodising? Been thinking of doing some myself.
Posted : 09/11/2011 2:51 pm
great work nicknoxx. And jameso, now Im a proud owner of one of them noodly things, that looks a great idea.
This is my bodge of a speedbone to fit a rohloff into a Ti29er with slotted dropouts.
Posted : 09/11/2011 2:54 pm
Chainguide for my Absolut SX, made from 2 x DMR old Chain Reactor hinged clamps and a Superstar plastic guide. I've used DMR clamps many times before along with a MRP/DMR roller, bolt and spacers but this time due to the bend in the seat tube, the position wasn't quite right and I couldn't get the guide to sit low enough, hence the extra bracket made from a cut down clamp.
Works very well, quiet as a mouse, but the plastic guide is susceptible to being knocked upwards out of alignment - I guess serrated washers may help . . . or less crashing 😆
Posted : 09/11/2011 3:08 pm
nixie - Member
No, I did it myself using drain cleaner, battery acid, an old lab power supply and some clothes dye.
It's dangerous, smelly, inconsistant and takes ages.
If you want to spend your entire evening dressed in overalls, rubber gloves and goggles, with your eyes watering and the hairs in your nostrils burning, all to produce one anodised trinket that you might have to strip back and do again, then it's a great pastime. Otherwise I'd recomend getting someone else to do it for you. Far more sensible.
You can buy kits though, like this one:
http://www.frost.co.uk/automotive-electroplating/aluminium-anodising-kit.html
Posted : 09/11/2011 3:38 pm
You can't beat a bit of good old fashioned drilling.
I was told this would explode in flames and kill me if i so much as looked at it. 😆
Still going strong along with three others that i've done the same to.
[url= http://farm5.static.flickr.com/4108/5208492767_af289ac421_z.jp g" target="_blank">http://farm5.static.flickr.com/4108/5208492767_af289ac421_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/5208492767/ ]2010_1126cheeserim0015[/url] by [url= http://www.flickr.com/people/stu-b/ ]singlespeedstu[/url], on Flickr
[url= http://farm6.static.flickr.com/5210/5217179471_7ef6707458_z.jp g" target="_blank">http://farm6.static.flickr.com/5210/5217179471_7ef6707458_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/5217179471/ ]2010_1129cheesewheel0025[/url] by [url= http://www.flickr.com/people/stu-b/ ]singlespeedstu[/url], on Flickr
[url= http://farm6.static.flickr.com/5255/5438522808_e57be65097_z.jp g" target="_blank">http://farm6.static.flickr.com/5255/5438522808_e57be65097_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/5438522808/ ]2011_0212holeymarge0004[/url] by [url= http://www.flickr.com/people/stu-b/ ]singlespeedstu[/url], on Flickr
Posted : 09/11/2011 4:05 pm
The last one looks like it could be fun when it gets muddy.
Posted : 09/11/2011 4:33 pm
Pretty simple one here , fixed on a centerlock hub
Posted : 09/11/2011 4:54 pm
 flow
Like conventional builds aren't strong enough, and missing a few sprockets will make all the difference in weight.
Posted : 09/11/2011 4:56 pm
Top job on the rims. Did you weigh the bits you removed?
Posted : 09/11/2011 5:02 pm
 LoCo
Best thread in ages! Thanks chaps 😀
Posted : 09/11/2011 5:05 pm
then how about "because they want to..."
always been good enough reason for me
@M6TTF
First pic is my 50th birthday bike, completely custom.
Second pic is just a modified dropout on a Kona A (the one for sale).
@jameso Frame was made by Lynskey
Posted : 09/11/2011 5:06 pm
What? these bits? I think the swarf would have weighed about half as much as the bits that I dug out the holesaw. 😆
[url= http://farm5.static.flickr.com/4108/5209092010_1bd33dba71_z.jp g" target="_blank">http://farm5.static.flickr.com/4108/5209092010_1bd33dba71_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/stu-b/5209092010/ ]2010_1126cheeserim0017[/url] by [url= http://www.flickr.com/people/stu-b/ ]singlespeedstu[/url], on Flickr
I didn't weigh them but someone else did a before and after weighing job on the same rim with slightly bigger holes and recond it lost 300grams. 🙂
Posted : 09/11/2011 5:10 pm
Stoner,
What brake pads are you running in the M965-R XTR caliper?
They look bigger than the standard Shimano offerings.
PaulD
Posted : 09/11/2011 5:13 pm
Flow, it's just a better wheelset for someone who rides SS 29er. Adding gears for some rides is an option with the cassette mod. Choice is a good thing?
Posted : 09/11/2011 5:18 pm
What? these bits?
If you'd planned it properly, you could have made a lifetime supply of top-caps.. )
I didn't weigh them
I don't blame you, I wouldn't : ) just interested and I'm now looking at my holesaw and my P35s.. but no, just no..
Posted : 09/11/2011 5:20 pm
Pauld, standard shimano pads. might not be shimano brand, but they'll be the same form factor. photo was taken ages ago though. currently using SSC pads sintered
Posted : 09/11/2011 5:39 pm
Go on, go on, go on, go on. 😀
Oh that reminds me I've got a Kris Holm rim built up on an Alfine that I could take the drill to next.
Posted : 09/11/2011 5:51 pm
 flow
Errr, I already know that, thats why I have 10 speed with 3 chainrings, crazy idea eh!
Posted : 09/11/2011 5:56 pm
I'm resisting. But now wondering about a drilled out UST convertion winter front wheel project.
Posted : 09/11/2011 6:01 pm
SSS, my father-in-law stopped and talked to someone with drilled rims riding a Jones bike somewhere near Wordlsey Woods, Stourbridge about 6 months ago, it may even have been you. Said he was amazed by both the rims and the bike and was concidering taking a drill to his motorbike rims.
Posted : 09/11/2011 6:03 pm
So do I, crazy huh.
Posted : 09/11/2011 6:17 pm
Not a single speed if it has gears.
Posted : 09/11/2011 6:29 pm
Lunge.
I do remember chatting to someone and him mentioning trying to drill out his motorbike rims.
Posted : 09/11/2011 6:31 pm
home built 51mm offset U turn 29er frankenforks,
[img] ?psid=1[/img]
converted xtr dual control shifter systems to lovely disc brakes
[img] ?psid=1[/img]
home stripped and polished frame and jone-esque cranks
[img] ?psid=1[/img]
Posted : 09/11/2011 6:39 pm
Quite a few bits have changed since this picture was taken and I might have spannered the front one in a big crash a week or so ago (needs checking) 🙁
Posted : 09/11/2011 6:41 pm
I cut the arms off my Mountain Warehouse fleece, using a pair of kitchen scissors. Do I win the thread?
You only win if you did that to make arm-warmers..
Posted : 09/11/2011 6:44 pm
Arm-coolers.
No win?
Posted : 09/11/2011 6:46 pm
I'm not qualified to judge.. I just polish stuff. I'm off to do my helmet next.
Posted : 09/11/2011 6:51 pm
Can't really polish a fleece tbh, they just melt.
Posted : 09/11/2011 6:58 pm
The only other thing I can think of is a mud guard to protect the mechanism of my KS i950 dropper post (made out of part of an old mudguard) fitted to the saddle and the post. Loads of problems with mud causing the cable/mechanism to stick before fitting and absolutely none since (no pic, sorry).
Posted : 09/11/2011 7:03 pm
My drilled fat bike rims lost 400gm. Stu still slagged me off 🙁
I have other DIY conquests but I'm tired of keyboard warriors insulting them.
Posted : 09/11/2011 7:37 pm
Come on Al don't be like that it was nothing to do with your rim. 😉
Get em posted up.
Posted : 09/11/2011 7:39 pm
What do I win?
Posted : 09/11/2011 8:04 pm
Al, that disc fork was a bold DIY project and should be celebrated : ) Got any more like that?
Posted : 09/11/2011 8:06 pm
*cracks knuckles*
The one...the only...Frankenbike (mk 2)
[url= http://farm7.static.flickr.com/6226/6241201056_94e359efcc_b.jp g" target="_blank">http://farm7.static.flickr.com/6226/6241201056_94e359efcc_b.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
DIY carbon/steel brake mount - who'd have thought the steel would fail?
[url= http://farm7.static.flickr.com/6215/6237174444_2c0ab59415_b.jp g" target="_blank">http://farm7.static.flickr.com/6215/6237174444_2c0ab59415_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/6237174444/ ]IMAG0785[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
UK's 2nd full suss fat bike
[url= http://farm7.static.flickr.com/6222/6222499865_2c3480d4e2_b.jp g" target="_blank">http://farm7.static.flickr.com/6222/6222499865_2c3480d4e2_b.jp g"/> [/img][/url]
Full carbon mount
[url= http://farm7.static.flickr.com/6159/6172081270_0546b9deb0_b.jp g" target="_blank">http://farm7.static.flickr.com/6159/6172081270_0546b9deb0_b.jp g"/> [/img][/url]
Rear mount in carbon/steel
[url= http://farm6.static.flickr.com/5267/5775054459_b5a3d0713c_b.jp g" target="_blank">http://farm6.static.flickr.com/5267/5775054459_b5a3d0713c_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/5775054459/ ]IMAG0567[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Pompetamine gear hanger
[url= http://farm6.static.flickr.com/5297/5489305989_ed729fc962_b.jp g" target="_blank">http://farm6.static.flickr.com/5297/5489305989_ed729fc962_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/5489305989/ ]R0011072[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
drilled rims
[url= http://farm6.static.flickr.com/5095/5442680910_e22b83b025_b.jp g" target="_blank">http://farm6.static.flickr.com/5095/5442680910_e22b83b025_b.jp g"/> [/img][/url]
LAtest project
[url= http://farm3.static.flickr.com/2692/4540322606_5f4fd836e7.jp g" target="_blank">http://farm3.static.flickr.com/2692/4540322606_5f4fd836e7.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/4540322606/ ]untitled[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Posted : 09/11/2011 8:08 pm
Laughs at Al's lack of drilling skillz. 😉
Though the Fatmarinthingy could have been good.
Posted : 09/11/2011 8:14 pm
one insult, one back-handed compliment 🙄
MArrowfat will be awesome (when fixed)
Posted : 09/11/2011 8:17 pm
Inspiring. DIY carbon on brake mounts gets maximum points.
Posted : 09/11/2011 8:19 pm
Wheel not hub. Less dish -> stronger wheel for the same weight.
Posted : 09/11/2011 8:25 pm
But regular rear wheels are strong enough.
Posted : 09/11/2011 8:26 pm
cynic-al - Member
My 16st and flatland 360s say otherwise... even without rotation, beasting jumps, drops and rocky hell mean some insurance is worth a few less gears that you struggle to choose between anyhoo.
Posted : 09/11/2011 8:34 pm
If you believe it makes a difference...
Posted : 09/11/2011 8:50 pm
Weirdly mine is exactly the same, only slightly cooler as I used a piece of carbon 😉
Got a small sheet of it with a view to making the cage out of carbon in the long run, but not got around to it yet. Seems to work better than the normal Superstar guide as it's far stiffer, never dropped the chain yet!
Posted : 09/11/2011 8:56 pm
C-al how much rear wheel travel do you get on that fat beauty?
Posted : 09/11/2011 8:58 pm
@tazzymtb
Have you go any more details on those forks?
Posted : 09/11/2011 8:59 pm
"Do you mean the singlespeed hub mods above?? Surely its because you want gears but either don't need the full range, or want less dish in the rear wheel (for more strength).
then how about "because they want to...""
If its a Hope SS hub then you'd also get twice the pickup speed over a pro II as well?
Posted : 09/11/2011 9:00 pm
nicknoxx, yep I wrote a buffoons guide to frankenfork conversions for rockshox that I emailed out to interested ****lers a while back. email me and I'll dig it out for you
tazwadie At hotmail Dot com
Posted : 09/11/2011 9:03 pm
4" Stuey
Posted : 09/11/2011 9:20 pm
Neat njee20!
Posted : 09/11/2011 9:43 pm
