Leaving yer saddle ...
[Closed] Leaving yer saddle height untouched throughout all of your riding
I still miss TJ.....
Posted : 16/09/2012 10:11 am
A lot of people I see dropping their posts low tend to ride the steep technical bits very slowly. If you attack them, look ahead and use a bit more flow you won't need to sit on your back tyre.
This is contrary to what I've seen and experienced. Dropping your saddle means you don't need to sit on your back tyre because you've lowered your centre of gravity. Following riders with high saddles along humpy pumpy sections of trail I've noticed how slowly they have to ride because they don't have the leg range to absorb and pump the rollers.
Good video. I'd be happy riding everything apart from the gap around 4 mins in! Video example to some of the 'gnarr' types here how good skills can see you over decent obstacles.
GEDA - Member
Here's the Danish xc lads on the local dh track.
www.youtube.com/watch?v=uc8aLS4uKa8
Probably easier to have you seat right up on a smooth dh track than a trail with loads of roots and rocks that will catapult you over the bars if your weight is not low down. It is also much easier/possible to drop your heals.
Posted : 16/09/2012 10:18 am
I ride slower with the saddle all the way up. Don't like the feeling of it hitting you in the arse, I've had a few otb's thanks to that. Normally just leave mine all the way down now and stand up for pedalling..
Ok OP. What happens when you try riding with the saddle down?
Posted : 16/09/2012 10:25 am
Nothing really. I can still ride the same. I do feel a bit 'safer' on the bike on technical bits, but for me I'd rather know I can do it all without making adjustments to the bike.
imnotverygood - Member
Posted : 16/09/2012 10:30 am
I have a Gravity Dropper.
Tried it on my rigid 29er & FS.
Seems to make more sense on the FS.
I find it a faff TBH, but those Reverbs look good where its just a bar lever & theres no having to weight the saddle to make it work.
Posted : 16/09/2012 10:38 am
 FOG
Never mind this dropper post lark, yunki has the right idea for the ultimate accessory- retractable bollocks. If I had these it would have saved me a good deal of pain over the years and doubtless made my descending a lot braver than it is now. I suppose we could take up sumo and learn to massage them back inside the body!
Posted : 16/09/2012 10:42 am
It really does depend how you like to ride. If you just want to hold on and hope for the best like the lads in that video then thats fine. If you want to have a bit more fun on the jumps and the drops then put your seat down.
Posted : 16/09/2012 10:46 am
to me the the physics of this don't make much sense, and are certainly not in line with any personal experience.. you simply can't get a good attack position for a steep rough descent with a raised saddle..
If I'm descending on a steep trail, saddle up, and I encounter, rocks, big roots or boulders, then my centre of gravity is too high up and towards the front of the bike due to the angle of the trail (unless I have put my arse behind the post..
With your weight high and forward there is little you can do if said boulder, rock or root kicks the rear of the bike up.. if you're not over the back, then unless you're crazylegs crane or have go go gadget extendo arms to redistribute your weight, you'll get a saddle in the butt and as likely as not an OTB..
Posted : 16/09/2012 10:47 am
I've only read a few posts on this thread so appologies if I'm repeating others, but I just don't get the argument that if you drop your post you're somehow lacking in skill or technical ability; specifically the comments that glasgowdan copied in his post above.
Firstly it's a matter of preference. But secondly when you compare XC and DH you have two completely different disciplines requiring different bike setups. You can't possibly argue that a pro DH rider could do what they do with a tall post if they were just a little better. Nonsense.
A dropper post allows those with the inclination to mix up different trails without stopping. It's a matter of preference as noted above but I'd not leave home without one. I've just returned from a ride with a nice big hole in my knee where I got a jump wrong on a fairly technical decent, wouldn't call it a full on DH but it's as close as we get where I live. The damage proves that I'm still a long way from having the ability I'd like to have but I'd like to see someone ride that with a tall post with anything close to agression or speed - would doff my cap so to speak. I'd never do it 😳
Good post GD.
Posted : 16/09/2012 10:48 am
Certainly seems to be a touchy subject this.
Posted : 16/09/2012 10:51 am
you wouldn't think that it would really matter though would you..? Is it the old brigade fiercely clinging to tradition again..?
there were mentions earlier in the thread of riding pedigree and experience.. 😆
When I were a lad we all had wooden teeth and our legs were ground off to stumps before we were even allowed to [i]look[/i] at a bike.. I still rode up the north face of the Eiger in just my grandad's longjohns with nothing more than a kiss from my sweetheart to keep me safe..
never did me any harm..
Posted : 16/09/2012 11:04 am
You cannot ride a bike as effectively on DH tracks with the seat at pedalling height. End of story.
If you ride xc, crack on, but don't pretend it makes no difference when it comes to DH and jumps.
Posted : 16/09/2012 11:05 am
Hadn't dropped my seat on descents for 10 years or more,then I bought a dropper seatpost...Still don't need to drop it,it's just more fun with the post out of the way as you chuck the bike about more.....
Only got one on the one bike,so I'm stilly nearly as 'ardcore as all you lot who think it's beneath you to drop it,no doubt you all ride rigid SS's too,I do that well..... 8)
Posted : 16/09/2012 11:15 am
yesiamtom - Member
Remember you are probably riding XC which is as much about the ups and flats as the downs.
Sounds like as good an advert for a dropper post as I've ever heard tbh 😉
if they can get a dropper to a decent weight (sub 400g) I'll have one like a shot...oh and one that works.....and doesn't get sloppy....and works in foul gritty conditions....bugger 😥
Posted : 16/09/2012 11:16 am
Many views expressed here are a joke.
*goes and sticks a 500mm post in his BMX*
Posted : 16/09/2012 11:20 am
You can't go as fast down rough tracks with the saddle up high, because the rocks and what have you kick the back end of the bike up into your knackers and throw you over the bars. Dropping the saddle a bit gives you that extra room to maneuver your body and soak up some of the hits.
Unless you're happy to mince down descents taking a ball bashing or you've worked out a way to defy physics I can't see why it would be preferable to leave the saddle up 🙂
Posted : 16/09/2012 11:29 am
You guys should try riding a cross bike. Then when you go back to a mountain bike you'll realise dropping the seat is a luxury. LUXURY!
Another non-seat-dropper here. I guess I rarely ride anything that really needs it.
Posted : 16/09/2012 11:30 am
tazzymtb - Member
Not so far off it tbh... Gravity Dropper Turbo is 440g for a 75mm one I think, and mine's survived 3 years of constant Scotland. Mine has a bit of play now but then it's old and well used, new shims would sort it (not unreasonable after years of use and only one service)
Gravity Dropper Descender- ie nonremote version- is sub-400g but the weight difference to get the lever is too small for the handicap IMO
I think we'll see a lightweight,short, unreliable post first though- someone's bound to knock out a race day xc post sooner or later for people who don't care if it needs serviced every time you use it. After all, we've already seen them used in the XC Eliminator races (but only by notorious mincer Brian Lopes I think, who probably just needs to learn to ride a bike 😉 )
Posted : 16/09/2012 11:35 am
I can't be bothered faffing around dropping my saddle, if it gets steep I just get off the back, what's hard about that?
Posted : 16/09/2012 11:54 am
 mrmo
Maybe for some, the time spent changing the saddle height at the top of the descent and again at the bottom, means if they "mince" there way down they are still quicker? For most riders, most riding doesn't actual involve descents where time spent descending makes it worth the bother.
As for weight 400grams!!! get it down sub 250 and then we can start talking, 1lb just for a tube to stick a saddle on!!
Posted : 16/09/2012 11:57 am
As for weight 400g!!!
I was using this as a reasonable starting point. Personally for a dropper post I'd like a moon on a stick, but the bike it would be going on is a light(ish) weight loony hardtail so it's not a massive difference.
my racey bikes will stay weenie light and fixed post height though 😀
Posted : 16/09/2012 12:01 pm
Personally I don't GAF about 400g it's not worth worrying about. Having my saddle in the right place all the time however is worth a lot
Posted : 16/09/2012 12:04 pm
Getting stuck behind the saddle? no weight in the front wheel and it washes out? Back is not always the correct position to be in, down is sometimes better.
This comes from a long tome riding and never bothering to lower my post
http://singletrackworld.com/forum/topic/never-drop-saddle-but-want-dropper-seatpost
My feeling is that it was money well spent, I cant feel the weight differance at all
Posted : 16/09/2012 12:05 pm
mrmo - Member
You want a dropper post to be lighter than a Thomson Elite? That sounds realistic...
The weight difference between a decent dropper post and a decent standard post is less than the difference between a race tyre and an everyday tyre. Do you ride around on Sworks sausageskins all the time to save 200g?
Posted : 16/09/2012 12:08 pm
 mrmo
But i do GAF about the extra weight and can't be arsed with the extra maintenance, the extra hassle, having to fiddle with something. I ride a bike to ride a bike, I don't ride a bike as some extension of a WI meeting, for discussing the latest component on my bike, how rad i am, etc.
Different people, different reasons for riding, neither is right, neither is wrong.
Honestly i suspect dropper posts will fall out of fashion, some will stick with them others won't, cycling is incredibly fickle about components, about supposed upgrades.
Posted : 16/09/2012 12:10 pm
 mrmo
and a Thompson is hardly a light seatpost is it?
Wonder why a number of XC bikes come with cut your seat-tube, or similar setups for the seat post.
Posted : 16/09/2012 12:13 pm
I have three settings: seat post up when riding along the road and anything else boring and time consuming. Then when I arrive at the "play area" - the woods I usually put my saddle down to a medium height so I can still sit down on it and pedal - not very efficiently, but hey. And finally completely slammed for jumps.
Thing is I ride a SS so the saddle is probably my least used component.
Posted : 16/09/2012 12:25 pm
I could ride everything I do with the saddle up - as I asssume we all could.
however the optimum saddle height for pedalling is not the same as the optimum height for descending.
I have a dropper post and am unconcerned about the weight or looks penalty.
Posted : 16/09/2012 12:40 pm
mrmo - Member
Nope, but it's a sensible benchmark. You're as well asking for frames that weigh nothing as you are dropper posts that weigh 250g.
Posted : 16/09/2012 12:59 pm
 mrmo
but one persons idea of sensible isn't necessarily the same as someone else's?
For some people they might make sense, but it really depends on why you ride.
Posted : 16/09/2012 1:09 pm
Those bleating about the weight of a dropper post on XC bikes are missing the point, they're generally not intended for use in this category....you should be able to ride everything on a XC ride with the saddle up.
Dropper posts are intended for AM bikes and the burgeoning gravity enduro scene, there is a reason why the top enduro riders all fit dropper posts and why DH bikes have the saddle tucked out of the way....shifting bodyweight in an exaggerated fashion on a quick/steep/techy descent is easier with the saddle out of the way....its not essential but it it depends how easy and fast you want to make it for yourself.
I have a 140mm FS with a standard seatpost and i can ride everything i want to with the saddle up....but when i enter a gravity enduro (or the FoD mini-DH earlier in the year) i fit the dropper post because speed counts and its so much easier.
Posted : 16/09/2012 1:10 pm
mrmo - Member
Really not sure what you're trying to say there... Saying something is a good benchmark isn't a recommendation, it doesn't need to be the right post for everyone for it to be a useful comparison point 😕 That's kind of the entire point of having a benchmark.
Posted : 16/09/2012 1:14 pm
this is when a dropper post would come in handy
Posted : 16/09/2012 1:21 pm
What I like most about that vid is the ever-helpful guy with the old frame. That, and the feller with course tape wrapped round his head
Posted : 16/09/2012 1:28 pm
Classic video, i like this one too in a similar theme:
Posted : 16/09/2012 1:37 pm
Yeah, to be fair in the Ae one I reckon the only way dropper posts would have helped would be if you got about 5000 of them and resurfaced that corner with them
Posted : 16/09/2012 1:49 pm
I struggle with long sentences, but my 2p worth is that I don't think of my reverb as a 'dropper' post. It spends most of it's time dropped, and only gets raised for big ol' climbs. It just eliminates faffing at the top and bottom of trails, which I can't stand, as once we stop, it's never just drop the saddles and carry on, there's always a chatting to be done, and before we know it, 20-30 mins have passed!
Raiser posts ftw.
Posted : 16/09/2012 2:11 pm
Raiser posts ftw.
ooh, nice! I might be tempted by one of those..
In fact, if people start using this new standard, I might just wait til all the cheap dropper posts come on sale in the classifieds and see if I can convert one.. 😀
Posted : 16/09/2012 2:19 pm
You got-to-have-a-dropper-post boys are funny!
Why so defensive?
Why so open minded?
FTFY
Posted : 16/09/2012 2:43 pm
Enjoyed those last 2 videos! Its about cornering for me, you can't weight the bike up to its maximum without being able to move freely. Google finds this pic, which i think demonstrates it:
You corner and go downhill faster with the saddle down. Yes you still may be beaten to the bottom by a better rider with their saddle up, but if said rider put their saddle down it'd be by a greater amount!
Posted : 16/09/2012 2:48 pm
 mrmo
Really not sure what you're trying to say there... Saying something is a good benchmark isn't a recommendation, it doesn't need to be the right post for everyone for it to be a useful comparison point That's kind of the entire point of having a benchmark.
To me Thompson isn't a benchmark, just overhyped and overweight. That is my point, if you want an XC benchmark then pick something that is relevant. try a KCNC at sub 200grams
Posted : 16/09/2012 2:49 pm
Page 3 / 6
