large knocking from...
[Closed] large knocking from rear end
I have a very annoying and very noticeable knocking/clunking from the rear end of my stumpy. It has appeared pretty much out of the blue (two rides ago). I have replaced all of the pivot bearings and this hasn't fixed it. I have searched the forums and most people recommend replacing the shock bushings I cant feel any play at all in the linkage set up not matter how I try. The feeling is most noticeable when I am going slow and go over rough terrain. I have noticed that the rear cassette has a fair amount of play it - could a worn freehub possibly cause this knocking? The rear shock has just had a full service and I'm a little suspicious that the shop may have done something wrong. Any advice would be much appreciated.
Posted : 10/04/2016 7:08 pm
Shock rebound set to fast?
Posted : 10/04/2016 7:38 pm
Hub bearings?
Posted : 10/04/2016 8:16 pm
Mech spring loosened off, banging stay?
Posted : 10/04/2016 8:23 pm
If the knocking has only started since you got the shock serviced then borrow another shock & see if the knocking is still there,or if yoU think it's the wheel swap wheels,it's a process of elimination.
HTH
Posted : 10/04/2016 8:30 pm
Check rear rotor, caliper and adaptor too?
Posted : 10/04/2016 10:11 pm
Quite possibly the shock stroke reducer has come loose inside the shock
Posted : 10/04/2016 10:30 pm
