Kona Wah Wah DU bus...
[Closed] Kona Wah Wah DU bushings - can you buy them?
Guys
I've been looking around for the DU bushing that go in the Kona Wah Wah pedal
I only need the bushing and not the £15 full rebuild kit
Anyone know if and where they can be purchased please in the UK or ship to the UK?
Ta
Posted : 28/05/2012 9:35 pm
If you know the size/bearing code, try a bearing suppliers such as Simplybearings.
Posted : 28/05/2012 9:58 pm
Superstar nano rebuild kit works doesn't?
Posted : 28/05/2012 10:00 pm
Yep, either Superstar or Nukeproof rebuild kits will work.
Posted : 28/05/2012 10:06 pm
Nukeproof bushes are £1.99 each from crc
Posted : 28/05/2012 10:15 pm
What Phil H said but good luck getting them out. If they are the same as the nanos there is a lip that they sit on making them hard to drift out. You'll need a 10.8mm drift, I failed with a screw driver.
There is an interesting tool from DMR that might work. Basically a threaded bar that you force into the softer bushing and then use to it to get purchase on the bushing. They originally recommended a BMX pedal axle (9/16?) Worth a google as it seemed much easier than the drifting route if you can find a large bolt that would be suitable.
Posted : 28/05/2012 10:28 pm
I've got a Nukeproof bushing from CRC at £1.99 on order and see if it fits
Thanks to all who replied
Posted : 29/05/2012 12:04 pm
Just like to confirm they are the same...it fits perfectly
Posted : 06/06/2012 12:23 pm
