Knackered Crank ext...
[Closed] Knackered Crank extractor thread
So, I have in my hand a ISIS type chainset. It has rather crossed up and shreadded extractor tool threads on the drive side. Not yet fitted to bike.
I think the threads may still be usable if I'm careful. Might try and fit one of these captive type extractor come bolt things: http://www.chainreactioncycles.com/Models.aspx?ModelID=19226.
Any tips..?
Posted : 30/10/2012 3:50 am
fit it
use a gear puller to remove it IF you ever need to.
Posted : 30/10/2012 4:46 am
If? It's Isis. Bin it.
Posted : 30/10/2012 5:37 am
kiwijohn - Member
Explain please O Mighty BB type guru??
Posted : 30/10/2012 7:53 am
isis wasnt very good , Interface or BBs - the axel was too big so the bearings were too small .
BBs die frequently and easy. I used to have 2 expensive ones on warrenty rotation with Windwave and silverfish then i happened upon some cheap octalink XTRs and fitted them instead.
Posted : 30/10/2012 8:02 am
Isis is someone's joke on is all. It promised much and delivered none
Even if the the cranks were free still not worth the cost of a bb in my mind
Just don't last Longenough
Posted : 30/10/2012 8:04 am
Far better to be in this position than "i have an ISIS BB & arm stuck on my bike". I wouldn't fit it. If it's a super special chainset then find another arm, otherwise as said look for something HT2. The wanted section is very helpful and often more bargainous than expected!
Posted : 30/10/2012 8:10 am
There you go. A cross threaded crank set is a right off, which is one reason they have all but disappeared.
That said, I'm still running some Race Face isis cranks on my DMR.
Posted : 30/10/2012 9:38 am
Having had to hacksaw off a crank with shagged threads, my advice is bin it
Well, it's only the pub/leave it in town/fret not about it bike, so...on it goes!
Posted : 30/10/2012 9:02 pm
