KMC 11sp chain link...
[Closed] KMC 11sp chain links
Warning...
you need a tool to close and open these...nice one KMC you gits
change a useful removable link with one that requires a tool.
Posted : 15/06/2016 10:11 pm
Don't need a tool to close it, or at least I didn't when I closed one a few weeks ago, just a bit of pressure on the pedal.
Do need a tool to open it. Do they still say it's reusable? SRAM long since said they are single use. I guess tolerances are getting pretty tight. Edit... 11sp no longer officially reusable.
Posted : 15/06/2016 10:47 pm
Seems that the chain is so narrow though theres no way to make the link skinny enough to press in and release now, so it relies on sticky uppy bits to hold it together through friction.
I've opened and reused mine several times now and I'm not even remotely dead yet.
Posted : 15/06/2016 10:52 pm
Never needed a tool to close them. The cranks can be used to apply way more force than chainlink tools.
I think KMC are officially not reusable. Totally are though.
Posted : 15/06/2016 10:53 pm
My last one must have been on and off ten times, no issues.
Posted : 15/06/2016 11:23 pm
Anyone tried the ybn 11 speed ones from Merlin?
Posted : 16/06/2016 12:38 am
Use a 10 speed link , just that tiny bit wider for clumsy thumb and fingers out on the trail .
Posted : 16/06/2016 7:05 am
Yep use the crank tip to close them tool to open them (even works well on the 9 &10sp ones)
I'm trying to think of the last time I needed to split a chain at the link on the trail. I can't the only time I'm in at the chain is if it snapped - no need to break the quick link or if the mech is totalled - using a chain splitter is easy enough at that point.
Posted : 16/06/2016 7:08 am
I have the 11 speed KMC chain with the quick link. Yeah it does need a tool to get it on an off at first (I use the multigrip pliers method). Had it off a few times now though (I always remove the chain to clean the drive train) and it's at the point where I can do it by hand. Getting it fixed on I just pull the chain taut.
Posted : 16/06/2016 8:06 am
Well, i filed down the little lip on the connectors that mean it needs a tool, and now it goes on and off with finger pressure, yey, go me...
bloody KMC
Posted : 18/06/2016 9:12 am
I had the same problem last week, for the life of me couldnt get it off, ended up buying the removal tool from crc, £7 or something along those lines, dont think the tool for putting it back on will be required tbh
Posted : 18/06/2016 9:39 am
http://www.planetx.co.uk/i/q/TOJWPMLP/jobsworth-pro-master-chain-link-pliers
One of those tools you wonder how you coped without.
Posted : 18/06/2016 9:42 am
File it down a bit or just use a 10 speed one..
Posted : 18/06/2016 10:07 am
Fingers?
I bought 5 hand files for 3.79
I think I got a better deal TBH
Posted : 18/06/2016 12:05 pm
Fingers?
How could you be arsed TBH, for an extra couple of quid you get the right tool for the right job 😕
Posted : 19/06/2016 8:53 am
