(Jumping) How to co...
[Closed] (Jumping) How to consciously practice “heavy feet” during take off?
I am really pleased with myself after tonights ride, i havent been jumping much recently, but on a nice sized double in Esholt, I cleaned it really well, front wheel down first, nice and smooth 🙂
Posted : 16/04/2015 12:12 am
 Euro
Euro interesting advice, thanks. Can you elaborate on these points?
Sorry, Teamhurtyhurty, didn't see this before my semi-flounce, i'll try to expand.
Your pump is not like an on/off switch, it's more like a dimmer and you can dial in varied amounts depending on your need. Want to go long to clear that gap? Speed and a little bit of pump will do lovely. Want to go high? Turn the pump dial up to eleven - go can go slow and high or fast and very high but as your speed increases the actual time you have to execute the pump on the transition is shortened. That's why i think it's a good idea to have a take-off that's, at the very least, a bike length long when getting the hang of it - it's give you a bigger window to get the timing right.
Personally, i prefer to jump on a hardtail. With the rear of the bike not moving up or down, it's one less variable to worry about and unless you run the rebound fast (which i've found is bad and sore when jumping 😀 ) there'll be a suspension delay when you pump which can throw the timing out. For general jumping though, a full sus will do if that's what you're used to and all you have.
Successful jumping relies on timing your pump to match your speed and the transition of the jump. When starting out, you don't want to be turning up the pumpage dimmer too much until you are comfortable jumping with a little pump applied. Gradually increase your pump effort over time as you get comfortable with the bike getting air. You'll feel when the time is right to up apply more pump as your jumping will seem effortless. You'll might need to either slow down a touch or find a bigger jump if you are going to pump up the pump.
Today's programme what brought to you by the word Pump.
Posted : 16/04/2015 8:35 am
 D0NK
That is the point. But repeating that pulling = wrong is going to confuse people if they can't imagine how it's done without their arms pulling on the bars.
eggsackerly. Teaching/saying "don't pull up by bending you arms, shift your weight back and up and the bars will be pulled up by your (straight) arms" sounds like good advice to me
Just saying "Don't pull on the bars" when the whole point is to get the front of the bike in the air (for manual/bunnyhop/jumping whatever) is confusing.
/armchair-not-very-expert
and thanks to euro, maxtorque and others whose jump advice I shall endeavour to try out next time I find some 🙂
Posted : 16/04/2015 8:48 am
Mark Weir pump track
Posted : 16/04/2015 8:58 am
I learnt to jump on a BMX I still prefer to jump fully rigid as I still sometimes mistime the pump with suspension and it sort of bounces me into the air rather than I did anything much
Thankfully suspension is much more forgiving on landing
Amongst all the claptrap it has been informative
Posted : 16/04/2015 9:12 am
[i]Ooops someone is going to accuse me of trolling... I know they are... I can feel it...[/i]
nah, you're not trying to validate your opinions about yourself through the medium of belittling or insulting a group you unknowningly feel excluded from; are you?
Say perhaps like our friend Empty Bell
Posted : 16/04/2015 9:23 am
So.................. having read all this I know not to pull up with my arms, but I'm still confused about the pump.
Presta or Schrader, or one that will do both ?
Posted : 16/04/2015 10:47 am
You're thinking too small, you need to stoke up your gnarr a bit more ....
Posted : 16/04/2015 10:59 am
So you're saying i'm full of shit?
No, I'm saying that the 'heavy feet light hands' is widely considered a good default way to be on the bike. There are plenty of times when you actively weight the bars strongly and likewise pull on the bars with maximum force - but they are dynamic temporary moves.
Posted : 16/04/2015 12:51 pm
Wow, this has been an interesting read indeed.
Maxtorque's:
If you have timed all that right, as the bike leaves the lip of the jump, it's suspension should be fully drooped (uncompressed), your legs straight (or practically so), and you arms straightish. What really helped for me was thinking not about jumping up, [b]but about really trying to push the bike into the ground, practically trying to shove it through the face of the ramp.[/b]
and Euro's
OP - try this little experiment. Pretend you are on your bike and stand accordingly - feet where your feet would be on the pedals (with strong foot forward and knees bent) and hands on the pretend bars, elbows bent. Now jump as high as you can holding this position. In order to leave the ground, you will have lowered your body by bending your legs before springing up into the air. This is what the pump feels like and it's the bit that you need to practice. Once you can jump really high (you'll be bending very low indeed and springing up quickly) you need to work on the timing as far too many people pump out of sync with the ground they are riding - even when just riding trails.
These two bits have helped me figure it out the most. I sessions a (super) smaller jump last night out of a bomb hole and think I got the feel for the pump. I can say I definitely wasn't pumping before this thread so it's helped me out a load. Cheers!
I had a few moments where the saddle quite comfortably (oooerrr) touched my bum last night, but in a controlled phat-air-dude kind of way. Feet felt more planted. Guess it's now down to practice.
Cheers all.
Posted : 16/04/2015 12:56 pm
I'm gonna say it's not 'your arms' pulling the front end up, but the front ends gets pulled up, because it's attached, via the arms, to the body which has shifted it's weight further back. If you had Mr tickle arms the front end would not leave the ground!!
Posted : 16/04/2015 1:12 pm
This is how you learn to jump a bike
Posted : 16/04/2015 1:18 pm
/p>
I clearly have no excuse for not hucking the BMX off the loading bay at work!
Posted : 16/04/2015 1:52 pm
You didn't see the landing!
Posted : 16/04/2015 1:57 pm
[i]Guess it's now down to practice[/i]
aye.
You need to find a wee jump in the woods, something that's preferably got a shallow downhill run to it so you don't have to pedal to begin with, and something that's not too severe, and just spend time on it.
I love the way that great stack of tyres has a clothes washing line "prop" as if it'll do anything 😆 ...I wonder if the bike stayed in one piece
Posted : 16/04/2015 2:02 pm
Technically speaking his mates should all be laid on the ground for him to jump over, other than that its perfection! 😀
Posted : 16/04/2015 2:09 pm
"Remember, heels down"
Posted : 16/04/2015 2:17 pm
Aged 12/13 I managed to convince 10 of my mates (all squished like sardines) to lie down in front of my 5 brick high ramp....with absolutely no chance of actually jumping that far.But hey....I'd be fine.Pedalled like billy'o and just as as I rolled up the ramp kid number one pokes his head up just enough to give me the perfect kick and enable me soar serenely over the lot of them and another 6ft to spare.At that point I became legend far and wide (well both local schools) as [b]the[/b] bmx kid.
Best..Day...Ever.
Posted : 16/04/2015 2:18 pm
I did something similar...unfeasible amount of kids, me pedalling like a mad fool. At the very last minute, a kid in the middle (yes Neil Mackenzie, that would be you...) decides he doesn't want to be there, and starts to stand up...
The carnage was something to behold.
Posted : 16/04/2015 2:25 pm
chiefgrooveguru
Without wishing to sound rude, i suspect you may weigh a tad more than that 11yo kid in that pic! Hence the flat landing, might be somewhat more tearjerking..... 😉
Reminds me of this:
If i did that^^^, at my age, i would shatter into a million pieces like a dropped china vase!
Posted : 16/04/2015 4:13 pm
[url=
4[/url]
Dont pull on the handlebars
Posted : 17/04/2015 12:22 am
I've been on a number of skills courses now, and I've never really mastered jumping. I reckon, on reflection, that they've been the wrong sort of skills courses. They've always had one coach, calmly explaining techniques, encouraging practice and giving feedback on performance. I reckon I need to find a skills course where there are are several coaches who all stand around belittling and contradicting one another. Does anyone know where I could find such a course? 😉
Posted : 17/04/2015 2:27 am
A kid at school once asked me how to bunny hop... I had no idea, I just did it. Told him to hook one foot under his pedal and pull up, which kept him busy for a few hours. 😈
I find it really hard to explain how to do stuff to other people, especially jumping. Stay loose is the best advice I got! Just keep trying and it'll come good.
Posted : 17/04/2015 8:03 am
Posted : 17/04/2015 10:33 am
At that point I became legend far and wide (well both local schools) as the bmx kid.
Best..Day...Ever.
Sounds pretty similar to my cycling career. All downhill from the age of 13 😆
Posted : 17/04/2015 10:38 am
grenosteve - Member
Often the best technicians are the worst teachers. Paradox.
I still think that as far as the OP goes, there are literally hundreds of "how to" videos out there though and it only takes one of them to 'click' and help you progress a bit further.
Posted : 17/04/2015 10:41 am
My advice would be make sure that you have spent your youth riding bikes over jumps, walls, street furniture etc for several hours every day for several years.
Trying to learn from scratch in the spare 1.5 hours you get every Sunday when you're 40 years old is never going to work well. Especially when you spend a significant proportion of that time watching internet 'how to' videos.
HTH
Posted : 17/04/2015 11:05 am
Another useful tip is to build jumps.
I have just completed a new one in the woods and been practicing on it. Seems to work a treat. Nice shape and easy to relax and get it wrong as it has a good landing ramp.
I can build it up as I improve
Posted : 17/04/2015 11:16 am
Page 3 / 3
