I've got a little simulation spreadsheet thing, to show how a number of variables can interact with each other and ultimately affect two results. In the middle of all the equations is a step that splits a total into 3 percentages.
What I'm after is a way to graphically represent these %ages just to give a visual pointer as to what is going on. I *could* use one of those combined bar chart things, but I was hoping I could get something that looks a bit more polished.
Amy ideas either how to achieve this in excel, or what other program I could import my excel figures into?
dont quite get what you're after, but if you're able to send the data to me I might be able to see it.
Stacked histogram is probably what I would use.
Sounds like Stacked histogram on the primary axis for the percentages and use the additional series on a secondary axis
You could just show the markers on the secondary series and add some custom symbols say 'arrows'
Aye, stacked histogram is the bog-standard Excel method. I was after something a bit more... engaging.
I'm trying to end up with a display like the following:
[img]
[/img]
The %ages I'm calculating are a water layer, an oil layer and an intermediate emulsion layer, each as a percentage of the whole (not really bothered about gas for now). I'd like to be able to output a graphic like the above that alters the levels according to the % calculated.
Any ideas?
Stacked area chart
Set the background colour for gas etc
Have a look at the contextures site lots of useful links
Try conditional formatting of a group of cells representing the graphic. The number of cells needed would depend on the accuracy needed.
stacked bar chart with 0 gap would do it.
I think for my level of IT prowess, [b]robbo[/b]'s sugestion is the one that will cause me least headache, as I'm failing miserably to make the stacked histogram thing do what I want - it's displaying the three %ages as 3 separate bars... 😕
I shall peruse the contextures site as well today, instead of doing any actual work.
