Isle of Purbeck rou...
[Closed] Isle of Purbeck route recommendations
Hopefully on holiday this year in Isle of Purbeck, can anyone recommend a good route down there ? Starting in Swange.
I've memory mapped a quick bridleway route via corfe castle, Rempstone Heath, Godlingston heath, Studland etc... but not sure if I've hit the best singeltrack that is to offer around there, so local knowledge always a help.
Cheers.
Posted : 24/01/2012 11:30 am
Done both of the these the long one is better as it goes past the Square and Compass which all rides in Purbeck should do.
http://singletrackworld.com/trailguide/uk/south-west/the-isle-of-purbeck/
Posted : 24/01/2012 11:32 am
 jeff
The long route in the STW PDF has a few road sections that can be avoided. We prefer to stay off road as much as possible and ride the ridges.
Here's the figure of 8 we do - start as the long route in the STW PDF, but climb up to the radio mast on 9 barrow down, then descend to Corfe. (Extra climb/descent)
Go out of Corfe to the SSW, over Corfe common, join the STW route.
Just after Kimmeridge, check the flags etc and go west on the bridleway, take first right hand bridleway for a fun descent down to the stream. Head north, then take the super steep (challenging climb) dog leg BW to the right. Climb up to the ridge, past the Grange Arch and follow ridge back to Corfe.
Lunch in model village cafe.
From Corfe, Nine barrow down all the way to the Swanage road, then turn left and then right climbing up to the obelisk, then ballard down and old harry, Studland and a pint in the pub. (As per the Medium STW route)
Would be interested to hear of any extensions to the West another 10 miles would be great.
Posted : 24/01/2012 11:55 am
Ooh, I'm interested, never ridden down there but heard good things.
[i]check the flags etc [/i]
Explain?
How does the area hold up in winter? Thinking of going down there in late Feb. Does it stay rideable or turn into a clagfest?
Posted : 24/01/2012 12:03 pm
 jeff
There are some firing ranges to the west and some of the trails close. I _think_ the extra bit we do is outside the area but double check the boundaries on an OS map ๐Ÿ™‚
In winter the possible problems are slow/soft grass + headwinds on the top of the ridges, and slippery chalk on some of the sections. No boggy sections, apart from one that I can remember.
Some friends did this route last w/e, all fine apart from the draggy grass and the usual cafe was shut for the winter!
Posted : 24/01/2012 12:24 pm
[i]In winter the possible problems are slow/soft grass + headwinds on the top of the ridges, and slippery chalk on some of the sections.[/i]
So potentially not very newbie friendly then?
Posted : 24/01/2012 12:27 pm
These guys might be able to help. They are base around wareham i think.
http://dorsetroughriders.com/
Posted : 24/01/2012 12:40 pm
 jeff
Maybe do the loop from Swanage to old harry and then make a call on the second - good thing about the figure of 8 is that there are bailout options, plus good cafes in Corfe etc.
Not techie riding, just chalky fire roads and open downland.
Posted : 24/01/2012 2:34 pm
 S_J
There was a loop in MBR a few years back which was ok. However, it did this BW as a climb but it's a superb descent so I'd try and include it...
http://www.streetmap.co.uk/map.srf?x=397182&y=79167&z=120&sv=397182,79167&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=841&ax=397182&ay=79167&lm=0
Posted : 24/01/2012 2:43 pm
A lot of the interesting/fun singletrack stuff (Franks tank etc) is in the golf course area. Easy enough to find if you know where to look (er that sounds a bit rubbish).
A good 30+ mile route is easy enough to link together, but i'm not sure how to set a link up to one here.
Put a thread up nearer the time or mail me and i'll show you around if you want.
Either that or give the guys at Ride Cycleworks in Poole a buzz as they run large group rides over there a couple of times a week (including beginners rides for newbies). If you are staying in Swanage, pop into Charlie the Bikemongers and he'll probably be able to point you in the right direction too.
Rusty
Posted : 24/01/2012 2:54 pm
 DrP
I've linked to some routes in my dropbox folder...
[url= http://dl.dropbox.com/u/54855100/GPS%20routes/Long%20Hilly%20Purbecks.mmo ]Long-Hilly Purbecks[/url]
[url= http://dl.dropbox.com/u/54855100/GPS%20routes/STW%20Prubeck%20ride.mmo ]STW Purbeck ride - my favourite[/url]
[url= http://dl.dropbox.com/u/54855100/GPS%20routes/Swanage-Purbeck%20WMB.mmo ]Swanage-Purbeck WMB mag ride[/url]
All mmo files....
DrP
Posted : 24/01/2012 2:58 pm
 vd
S-J is on the money about that descent. After the first 200 yards on unpromising mud and ruts it turns into a great rocky track, arguably the best in the area if you like a challenge. Why anyone would put together a route using it as a climbe beats me, however. Track to the west is a better way up if you want to do S-J's recommendation down.
Posted : 24/01/2012 3:09 pm
wow, lot to process, many thanks.
Posted : 24/01/2012 3:55 pm
 DrP
The descent S-J mentions is on (i believe) the second route I posted (my fav!)
It is a cracking few hundred yards of descent - pretty hairy if taken at speed!
DrP
Posted : 24/01/2012 6:38 pm
 jeff
Interesting! Will work out how to add that into our regular route.
Posted : 25/01/2012 12:57 pm
