is there anyway to ...
[Closed] is there anyway to glue this brake back together?
[#6194036]
Snappedit, having to much fun at the Dyfi, just got round to cleaning the bike up and want to go riding before the replacement lever arrives (next week now) I used duct tape during the Dyfi to fix it up but surely I could use some sort of glue, to get a little more use from it!? Maybe combining more tape to support it I guess.
Thoughts?
[URL= http://i197.photobucket.com/albums/aa165/Shitbreak23/Mobile%20Uploads/IMAG0005_zpsm1yjj5kx.jp g" target="_blank">http://i197.photobucket.com/albums/aa165/Shitbreak23/Mobile%20Uploads/IMAG0005_zpsm1yjj5kx.jp g"/> [/IMG][/URL]
Posted : 15/05/2014 4:40 pm
for the sake of saving £16.50 and with next day delivery
is it really worth trying to bodge something as critical as your front brake?
[url= http://www.chainreactioncycles.com/shimano-deore-m615-disc-brake-lever/rp-prod108825 ]CRC spare lever assy here[/url]
Posted : 15/05/2014 4:46 pm
How much do you value your face?! I'd 've replacing that!
Posted : 15/05/2014 4:47 pm
Initial thoughts are that I think you are underestimating the forces it's subjected to and overestimating the strength of glue and tape. However, if you want to give it a shot, your best bet I reckon would be a metal filled two part epoxy (JB weld or similar) applied exactly per the instructions after cleaning the surfaces to be glued very carefully and then leave it somewhere warm to set for at least as long as it says on the instructions. It may or may not hold together.
Posted : 15/05/2014 4:48 pm
I think I'd rather ride with just one brake than risk that TBH. One brake will be fine if you don't go mad 🙂
LOL. I can't believe you're asking. That is new lever time.
Tape and zip-ties are for emergency trail side repairs. For £16.50and d new olive that will be as good as new with no nagging doubts and potential for wilderness failure.
Posted : 15/05/2014 4:56 pm
Cable ties.
What's the worst that could happen?
Posted : 15/05/2014 4:57 pm
Glue... 😆
Kids these days...
[url= http://www.itw-devcon.co.uk/index.php?/devcon_mro/epoxy_maintenance_repair_and_overhaul_systems/devcon_titanium_putty/ ]But here you go anyway[/url] It'll cost a fortune, not last very long and TBH the spare lever will probably arrive from CRC by tomorrow won't it?
TBH I'd be more worried about what state the bar was like underneath, I'd imagine a fair bit of force was imparted as your lever snapped...
Posted : 15/05/2014 5:05 pm
I can't work out how you could possible use a brake with it slammed up against the grip like that! Are you using four fingers on the lever or do your hands hang of the end of the bars?
Posted : 15/05/2014 6:48 pm
I'd use carbon wrap. And a spoon.
Posted : 15/05/2014 6:55 pm
JB weld is about the best, but needs best part of 24hrs to fully cure so probably not worth the effort given you will need to replace it anyway.
Posted : 15/05/2014 6:57 pm
Damn you! I was just about to suggest that!
Posted : 15/05/2014 7:00 pm
I'm getting the whole replace the lever concept!
Hence
Just thought I'd ask if there were thoughts on a quick but reasonable fix in the meantime!
I guess so.
Thanks but a little more than I'd care to spend!
I'll think I'll wait until the delivery.
I've small hand's and short finger's, Why would I make it harder for myself?
Posted : 15/05/2014 7:16 pm
If you had to...and I mean HAD to use it. I'd try to drill a couple of little dowels into each part made out of a bit of metal rod(cut down nails perhaps.) and epoxy resin the bejeezus out of it. But, you don't HAVE to use it so probably don't, unless it's towpath or something...
Posted : 15/05/2014 7:40 pm
I love the fact that you just want a bodge to get out and ride. Kudos.
Posted : 15/05/2014 8:15 pm
Nobody on here that can lend a brake? I'm guessing since you were at the dyfi you're not near me but if you're Edinburghish you'd be welcome to one of my embarassing brake mountain for a while
Posted : 15/05/2014 8:24 pm
Since you are waiting for a replacement, I'd stick a jubilee clip around it and clamp as hard as it will go. Forget the glue.
Posted : 15/05/2014 8:50 pm
A jubilee clip is an EXCELLENT idea. In fact, with a couple of jubilees and a custom made shim that runs the length of the master piston, that would be a good long term fix. However, in the time it takes to shape and set the shim correctly, the new lever will have arrived.
My trailside fix would be a spacer/shim whittled from a piece of wood with a Leatherman, followed by ziptie apocalypse.
But I'd be ordering a new lever as soon as I had phone reception...
Posted : 15/05/2014 9:36 pm
