Is my heart rate mo...
[Closed] Is my heart rate monitor failing? (part 2)
 JAG
A little while ago I started this thread...
By the end of the investigation I'd decided the problem was my own for not licking the contacts on the strap. Just to be sure I cleaned up the contacts (for the battery) and changed the battery. All has been good.
Anyway; fast-forward a month or so and the problem has returned. Garmin Edge 500 is occasionally reporting heart rate of 200-250 bpm. It happened a couple of times yesterday on my commute to work. On my way home I didn't wear the strap and simply shoved it in my rucsack.
However during my ride home I noticed that my Garmin Edge 500 is STILL reporting a heart rate value - even though the HRM strap is in my rucsack and can't be transmitting a signal!
Is the Garmin Edge 500 borked?
Anyone else had a problem like this?
What the hell do I do now?
I've had a search on t'internet and can't find any other reports of this problem :o(
Posted : 17/07/2019 3:56 pm
Itll still pick the sensor if the little black plastic bit is popped onto the 2 studs.
It's probably a knackered HR sensor to be fair, they're only cheap so try a new one
Posted : 17/07/2019 4:10 pm
 Haze
Much of the HR weirdness I've seen has been fixed by either washing the strap or a battery swap.
Apart from once, it was years old though so bought a replacement.
Posted : 17/07/2019 5:25 pm
