Is my bike to small...
[Closed] Is my bike to small for me??
But pop...all 29ers look silly! I mean they were ridden by beardy niche whores, then became mainstream and have since been replaced by 27.5 gnarpoons...god you are like...soooo behind the times
Posted : 06/03/2015 10:00 pm
 ton
you bastard........... 😥
Posted : 06/03/2015 10:03 pm
But ya loves me ton, now give me a big man cuddle 😀
Posted : 06/03/2015 10:08 pm
Hi Renton,
Your bike is the right size for you. But it's a 150mm travel bike; they're meant to be ridden stood up and down a trail. The sizing/geometry reflects this
If you want a bike you can stretch out on, then get an XC 29er thats designed to for that,.
Posted : 06/03/2015 10:20 pm
About the longer fork q, it may help but only if more saddle set back from the bb helps you feel comfy on the bike. Dtf's right, could just be the bike isn't the fit you expected but it'll be good once used to it.
Posted : 06/03/2015 10:36 pm
I'm another 183cm guy, and my TR is a fair bit shorter in reach than yours as well as it's predecessor, but now I'm used to it I love it and have done my longest rides yet aboard it. That seatpost extension looks similar to mine (32" inseam myself, see my link for extension), so I'll go against the grain and suggest you get out on it for some time and get used to it !
.html
Posted : 06/03/2015 10:57 pm
I'm just under 6'5" and had a large trance, it was a bit short for sure, I now have a large Yeti AsR5, and that is also a bit small. I'm now getting an XL 29er. I look like I'm on a bmx on a 26er
Posted : 07/03/2015 12:00 am
 ton
Renton = the next generation Hora?
Posted : 07/03/2015 12:25 am
Davidtaylforth has a point, the Trance is a medium/long travel trail/AM bike and should be ridden for purpose stood up.
I believe you commute on the bike don't you Renton?....I reckon that is skewing your view on things, I reckon out on the trail that bike fits you fine when stood up and shifting weight around.
As someone else said, if you want a comfortable commuter bike maybe consider a large or XL 29er short travel machine.
I ride a 16 inch hardtail that has me constantly shifting my bum to the rear of the saddle and draping my wrists over the bars for more room on flat sections of trail, on that basis its way too small....but when things get interesting and I find some singletrack, jumps, drops, roots etc I stand up and centre myself in the middle of the bike and it feels perfect....and really that's all that matters, I can live with feeling cramped on fire road climbs for a perfect fit when the trails demand I ride it properly.
Posted : 07/03/2015 8:05 am
As a 6'2" guy With a 34" inside leg have a couple of observations.
I used to have a size L 5 Spot and I was happy with the sizing, then went to my size L Bandit, which has a shorter top tube, and am happy with that.
I'm sure if I saw a pic of me on the bike I'd look all gangly and awkward but it feels ok.
Mind you, I use 780mm bars, which open out the arms and a slightly longer stem than you, no less than 70mm. Being a taller chap I think you have to take things like bar width and stem length as relative, and not necessarily just go for the shortest or widest as fashion dictates.
Also, you mention feeling like you are moving your weight off the back of the saddle constantly? May be teaching you to suck eggs but have you tried either tilting it ever so slightly forward, or trying a saddle with a slightly flared/wider back (Fizik saddles like the Nisene used to be like this) to give you something to 'push' against? Has worked for me in the past.
Your pic, it may be the way the shorts fit, but in the 'full leg extension' one although your leg has a slight bend with your heel on the axle, like convention dictates, it looks like your hip is rotated, although it may be an illusion. Is the seatpost definitely not a little too high?
Lastly, try not to overanalyse it. Once you get it feeling 'right' it will be right, regardless of what it looks like. You should see how daft my Klein looked back in the day, 130mm stem and 420mm seatpost at full extension!
Posted : 07/03/2015 8:06 am
If it feels fine on the trails but rubbish on the commute, I'd be looking to spend a few hundred quid on a commuter bike that fits and use the Giant for the purpose it's intended.
False economy anyway riding a brand new 150mm travel MTB on the roads every day IMO as you're wearing out some very expensive parts.
Posted : 07/03/2015 8:13 am
 br
[i]As a 6'2" guy With a 34" inside leg have a couple of observations.[/i]
Me too, although I'm more +34" and for whatever reason modern mtb's seem to have got short/small etc.
I demo'd a large Orange 5 650B, and decided that if I bought I'd be buying an XL - still plenty of clearance, would run with a 35mm stem and a 150mm Reverb. Pals' have bought Canyon's, Codeine's and Capra's - the large size ain't big enough for me (most due to knees knocking the controls when out of the saddle).
I'm currently on 20" frames, a Cube Stereo and 456Ti - and quite frankly, how they look when I'm riding them I don't care.
Posted : 07/03/2015 8:34 am
Looking at the pics I'd forget all about what is supposed to be right according to Giant and try a few bits to see if it fits better.
As a play in the woods and launch off everything it looks ok, but for general riding and XC where it is important to go up as well as down I'd suggest your arms are a few degrees too close to your torso when on the bars.
For what it costs try a 80-90mm stem and rotate your bars to give differing levels of reach. Clearly it may/will put your hands in a funny position but it will give you a true indication of how stretched you need to be for it to feel right.
If it feels and rides good then sod the rule books and fashion trends imho.
Posted : 07/03/2015 9:27 am
The bike is suitable for some one 6 foot to 6 foot 4. How am I too big for it.
Because height is a really lazy and overly simplistic way of sizing a bike.
Options...
Layback post
Longer Stem
Hope the frame cracks and you can get a bigger replacement.
Posted : 07/03/2015 9:43 am
Although they seem to have ' relaxed' all of their trail/ Enduro bikes from how things were five years ago, ( I'm 5'10 and ride a 2008 medium trance with a 140 fork) ,Giants have always felt a little ' short' to me whilst other dimensions seem spot on.
As supplied mine came with a 100mm stem. I went for a wider bar / shorter stem option and originally bought a 50mm stem and the bike felt truly horrible. Simply changing the stem to a 70mm one made a night and day difference for me, it allowed me to get some weight over the front wheel and put me just a little mor comfortably more into the middle of the bike. I was quite surprised at how big a difference it made and it's been with the 70mm stem and a 760 bar for five years now.
Presumably you don't normally ride with your arms as straight as they seem in the pics ?
With regard your knee pain, although the pics do look a little odd as the lens is skewing a proper side on view, I'm tempted to suggest , that for general trail riding, maybe you saddle is half an inch too high ? Just maybe the photo though.
Posted : 07/03/2015 9:59 am
If it does feel too small you could always try selling it or swapping...
http://www.pinkbike.com/buysell/1722389/ 😉
Posted : 07/03/2015 10:06 am
So stevied what relevance does that have at all ??
The bike came as standard with a 70mm stem and 730mm wide bars.
I've changed the bars to 780mm as always and that helped.
I really don't understand why it feels smaller than my old bike as the measurements are nearly exactly the same.
Seat angle on 5 spot was 73 , trance is 73.5
Head angle on 5 spot was 69 , trance is 67 so slightly slacker.
Posted : 07/03/2015 10:15 am
I don't know you let armourers loose in the real world and this is what happens! You should stick to bangy things and singing "a-I'm an armourer, b-I'm an armourer, c-I'm an armourer". You know the words, join on in 😉
Do a load of demos next time mate.
Posted : 07/03/2015 10:17 am
The bike [u][b]IS[/b][/u] fine size-wise.
Go back to a longer stem and all will be well, think about a dropper if you are struggling to get your body back over the saddle after a descent (or drop your saddle a bit like the ole days:-)
It takes time to adjust to new bikes mate (especially if you haven't been riding much in between bikes.) Find some good trail and slowly find what it is good at.. pedal it loads for a coupla months and if you don't like it after a thousand miles swap it for something else. 8)
Posted : 07/03/2015 10:23 am
Do these make it clearer.............
[URL= http://i2.photobucket.com/albums/y33/renton1/002_zpshbmklphp.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/002_zpshbmklphp.jp g"/> [/IMG][/URL]
[URL= http://i2.photobucket.com/albums/y33/renton1/003_zpspgcfxnkf.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/003_zpspgcfxnkf.jp g"/> [/IMG][/URL]
[URL= http://i2.photobucket.com/albums/y33/renton1/004_zpshlbaa40h.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/004_zpshlbaa40h.jp g"/> [/IMG][/URL]
[URL= http://i2.photobucket.com/albums/y33/renton1/005_zps0ovkmtzt.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/005_zps0ovkmtzt.jp g"/> [/IMG][/URL]
[URL= http://i2.photobucket.com/albums/y33/renton1/006_zpsfd71qr2f.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/006_zpsfd71qr2f.jp g"/> [/IMG][/URL]
Posted : 07/03/2015 10:46 am
Ive also stuck the 70mm stem back on and it feels better.
Posted : 07/03/2015 10:47 am
Just go and ride the ****ing thing and stop fannying around taking pictures of yourself.
Posted : 07/03/2015 10:55 am
Find somewhere you can use the bike as intended and then have a rethink. Tootling around on it will tell you nothing.
Posted : 07/03/2015 11:00 am
Drop the saddle 5mm. Go ride. Biggest problem, as some have said, is probably just that you're using a reasonably 'aggresive' bike for pootling. DO NOT base you rambling paranoia on commuting on the thing.
Try sliding the saddle back a bit?
Posted : 07/03/2015 11:01 am
Nice socks
Posted : 07/03/2015 11:03 am
That looks absolutely fine to me, for a trail bike. I wouldn't want to commute on it but that's got less to do with size and more to do with just about everything else.
Posted : 07/03/2015 11:04 am
'I've got this bike I really like. It rides nice but my baggy gear gets caught on the saddle so I changed the stem and now it's horrible. Looks ace leaning up against the wall though. What should I do? Leave it cause it looks fab or change it back because it's borderline unridable?'
Stop messing with it you big Mary and ride it. If it's horrible with the short stem on then the longer stem it is. Drop your seat at the top of steep tech to enable you to clear it without getting hung up on it. If you don't want to stop then save up for a dropper post. A photo of you standing over the bike would have been helpful.
Posted : 07/03/2015 11:06 am
I reckon that just needs riding now. Forget what went before , just ride it, maybe you'll find yourself rolling the bar back and forth, or altering shock / fork pressures and stuff, but looks ok size wise.. Focus on the ride , not the bike and too many 'what ifs'.
Posted : 07/03/2015 11:09 am
Cheers for all the replies.
I have loads of bikes over the past 5 or 6 years and never struggled to get thrm comfy or dialled in as much as I am with this one.
Posted : 07/03/2015 11:29 am
It doesn't look that bad to be fair. To a certain extent, top tube length is personal preference. That bike is probably a bit shorter (for you) than many others but it's not a deal breaker and if it's comfortable then just ride the thing.
Posted : 07/03/2015 11:38 am
I've just got the same bike (but in medium) and I will concede that it did take me a while to get used to.
There is something 'different' about how Giant do their bikes compared to the previous Treks, On-Ones, Ragleys, Saracens, GTs and Spesh's that I've owned.
It came down to mindset, the bike is the right size for me (according to Giant) as yours is for you....so have faith in a proven suspension design, good build quality and known quantity components. You're not trying out a start-up brand here, as others have said focus on the off road ability of the bike not the commuting comfort and let it do what it was designed for....you'll find it's actually pretty good!
Posted : 07/03/2015 11:42 am
Yep cheers
I should point out that I bought the bike second hand so never had the chance to demo.
I was always going to buy my next bike second hand so did some research and compared the geometry of lots of bikes against my five spot.
Apart from the longer reach and shorter seat tube the trance came up almost the same but with newer angles but since I've had it it hasn't felt right yet. Something must have got lost in translation somewhere.
My five spot could do everything I wanted. I could commute on it to work but the detour off on the way home into the woods and do some trails.
The Trance is proving harder and slower to commute on but is near enough the same if not faster in the woods, in fact I've come top 5 on strava on a track I've never done before on the trance.
My problem now is that I need a bike predominantly to commute on and then also able to through around the woods.
How do I get the trance to be that one and only bike??
EDIT: The shock has blown so I need to get it into my local Giant dealer to get sorted.
Posted : 07/03/2015 11:51 am
I tend to think n+1 is bullshit, but in this case it's just not going to happen.
Posted : 07/03/2015 12:24 pm
By getting on it and riding it without worrying about the fact that it isn't technically the 'right' tool for the job. N+1 is only applicable if you can afford/justify it. If you can only afford/justify one bike then make sure it's a bike that you want to ride.
Posted : 07/03/2015 12:53 pm
from the photo's it clearly looks too small (like you're riding a bmx).Increasing stem length etc aren't going to solve it. It's just looks too small for you.
Posted : 07/03/2015 1:02 pm
That's a HT at best, not a bike that's too short for you and with oodles of suspension.
Posted : 07/03/2015 1:52 pm
140mm isn't oodles is it ?
Posted : 07/03/2015 2:53 pm
Unless you turn them into hybrid-like things, MTBs are rubbish for commuting on. My Spitfire (which is a really great pedalling 6" full-sus) is brilliant up, down and along on the trails but turgid on tarmac. My Soul is a little better but not a lot.
If I didn't have a Brompton then I'd buy a long seatpost for my BMX and use that as a cheap singlespeed rather than wear out an expensive chain, cassette, chainring, tyres, etc etc. At least the BMX has tyres that roll properly on tarmac!
Posted : 07/03/2015 3:48 pm
Needs a 120mm 0degree stem on it fer starters, 780mm bars, fine. SPD's, layback post, and a change of socks.
Doesn't look dirty enough for a proper critique, sorry.
Posted : 07/03/2015 4:08 pm
[quote=renton ]140mm isn't oodles is it ?For riding in your local woods?
On One are selling the Dirty Disco for £800 at the moment.
Posted : 07/03/2015 6:10 pm
 br
[i]I was always going to buy my next bike second hand so did some research and compared the geometry of lots of bikes against my five spot. [/i]
Also, never ever trust any manufacturers measurements - if they lie at weights then why believe that the geometry or size data is correct?
I also bought my FS s/h and unseen but having ridden a friends (more modern) Cube had an idea that their sizing would fit me - and it has.
Posted : 07/03/2015 7:28 pm
I gave up reading the comments so maybe this has already been asked....but is the suspension set up correctly? Looks like the fork isn't sagging much, but the rear shock looks like it might be halfway through it's travel judging by the rocker? Something looks wrong.
Posted : 07/03/2015 7:47 pm
Sag is set correctly mate.
Posted : 07/03/2015 7:54 pm
Sounds like a cross bike would be perfect for that.
Posted : 07/03/2015 8:13 pm
There is a lad that wallops me on a cross bike every morning on my way to work.
Posted : 07/03/2015 8:33 pm
 hora
Renton itll be too small if it was for pure XC. Im 6ft1 and ride a medium SC Butcher with.....a 50mm stem.
Its going to the Lakes throughout Summer this year 😀
Just ride it.
Ride it
Ride it.
Posted : 07/03/2015 8:40 pm
 hora
Heres mine with short stem
https://m.flickr.com/#/photos/30625376@N06/16537987797/sizes/o/
Posted : 07/03/2015 8:47 pm
Hora that must be well small for you. Don't your knees hit the bars at all.
Post a pic of you sat on it.
Posted : 07/03/2015 8:51 pm
 hora
Honestly no they dont. I'll get a pic tomorrow. Dont forget SC of old have shorter than normal TT as well.
Posted : 07/03/2015 8:53 pm
So how does it fit you then. ??
It has a 22.5 ett. I would be on an xl one of those.
Posted : 07/03/2015 8:59 pm
Unless 6'1" really means 5'7" then it doesn't.
Posted : 07/03/2015 9:03 pm
:mrgreen:
Posted : 07/03/2015 9:06 pm
 hora
The only size guide I go by is shoes.
Everything else; jeans, shirts, bikes is subjective.
Its a guide.
Renton, you seek and search like a Nomad. Find a brand with collective angles that you tend to like and stick with them.
Mines SC, yours is Specialized(?) Or?
Posted : 07/03/2015 9:13 pm
Lower the stem, maybe stick a sligtly longer one back on, roll the bars forward, slide the saddle back; maybe benefit from a dropper. All of those things will give you more room in there. Otherwise buy some golf clubs and really learn how to hate your sport!
Posted : 07/03/2015 9:44 pm
Keep the 50mm stem and get a new bike that fits you... 😀
Posted : 08/03/2015 9:18 am
You say that everything's pretty much identical to your old 5 Spot, except the HA is 2 degrees slacker - would've thought that would be making a difference. Also agree with simondbarnes about the fork sag, which is probably taking off another couple if degrees.
But then I haven't ridden a FS bike for about 12 years.
Posted : 08/03/2015 9:20 am
I have the same issue im bang in the middle of the small and med ended up going small with a long post and 80mm stem its abit iffy on all day pedely rides but when in "attack" possition it spot on i just have long legs and short upper just take it on the chin and ride the shit out of it.
Posted : 08/03/2015 11:55 am
It is if most of the ride is on roads and inside the barriers. It isn't if you are hooning down hills for most of the ride.
Posted : 08/03/2015 2:46 pm
 hora
140mm is enough on the rear! 150mm front. Sorted.
Posted : 08/03/2015 4:37 pm
I'm going to suggest getting the front end lower. Spacers out from under the stem to try out at no cost, flat bar if it feels like it's working.
Posted : 08/03/2015 5:29 pm
renton - Member
When I have things (bikes, basses, cameras etc.) that "do everything I want" I tend to just keep them and use them. Seems easiest really.
Posted : 08/03/2015 6:41 pm
Unless you've got no room I would buy a cheap road bike for the commute and keep the trance - by the time you've bought and sold again you will have sent a few hundred quid anyway
Posted : 08/03/2015 7:04 pm
I've been out on it again today and it faired much better despite having a dodgy shock.
I went over to the moray monster trails and did the gulley monster which is a black run and quite tight and technical.
On the climb up I was blowing hard but that's a lack of fitness. The bike seemed quite eager to climb and never once felt like it was wondering around.
On the trail which is quite rooty the shock and fork felt quite harsh and my wrists and hands were a bit sore. Halfway down I switched to descend mode and I just couldn't tell what the rear end was doing. There are a few jumps along the trail and trying load the back end to spring up it just felt really soggy.
Apart from that and the tyres I felt as though I was getting on with it.
Posted : 08/03/2015 8:13 pm
Ditto. Last sold a bike in the '90s and have never sold a bass - have 5 of the former and 3 of the latter... Had to design my own bass cab because nothing did what I wanted and just look where that led me!
Posted : 08/03/2015 8:19 pm
Just buy [url= http://singletrackworld.com/forum/topic/fs-xl-charge-plug-3-road-bike-fitted-with-flat-bars ]this[/url] for commute.
Posted : 08/03/2015 8:32 pm
 hora
Renton I'd like a alu Bronson. Could you buy/dibbs please
Or see a head Doc for stress
Posted : 08/03/2015 8:43 pm
But your shock is borked so you decide to do a black!??
Posted : 08/03/2015 8:51 pm
So apart from the shock, the fork, the tyres & the frame, you seem to be getting on with it 😀
Soggy shock & harsh fork suggests not enough sag in the front & too much on the rear?
Don't forget the aqueducts 😈
Posted : 08/03/2015 8:53 pm
You should really get a bike that's suited to the majority of the riding that you do, otherwise the majority of your riding time is not as enjoyable as it could be.
Commuting on a 150mm full sus is no fun, neither is bombing round the woods (or not as much fun as it could be). It's silly have a bike that you might use to it's potential once or twice a year.
Get yourself a cross bike, or at the very least, a nice rigid/hardtail. They'd be perfectly suited to the majority of your riding.
Posted : 08/03/2015 8:58 pm
It's 140mm.
I am trying to get out more and more. Glenlivet Friday.
Hora oh the ironing coming from you
Posted : 08/03/2015 9:03 pm
Frame is fine. Just need to get used to it.
Tyres are personal choice.
Fork is still bedding in and I've probably got to much air in them.
It's the rear shock letting it down. Plus my fitness
Posted : 08/03/2015 9:05 pm
chiefgrooveguru - Member
You're as bad as me, man! I've got six bikes and five basses - although, in my defence, they're divided between here and Greece. I've decided that's it now though.
Posted : 08/03/2015 9:09 pm
It sort of got dirty today too...........
[URL= http://i2.photobucket.com/albums/y33/renton1/Mobile%20Uploads/IMAG0029_zpsrnx8nwui.jp g" target="_blank">http://i2.photobucket.com/albums/y33/renton1/Mobile%20Uploads/IMAG0029_zpsrnx8nwui.jp g"/> [/IMG][/URL]
Posted : 08/03/2015 9:14 pm
I does look a little small for you with all that seatpost and all those stem spacers. 😆
Posted : 08/03/2015 9:19 pm
:mrgreen:
If I keep it Im going to put a longer travel fork on it and hopefully get rid of some spacers.
Seatpost length is fine, means I can use a 125mm droppper when funds allow.
Posted : 08/03/2015 9:24 pm
 br
[i]Seatpost length is fine, means I can use a 125mm droppper when funds allow. [/i]
You've enough seatpost for a 150mm Stealth.
Posted : 08/03/2015 9:46 pm
nope, according to the size guide someone put up here the other day my seatpost length is about 2.5cm short for the 150mm
Posted : 08/03/2015 9:48 pm
Page 2 / 3
