Is it possible to r...
[Closed] Is it possible to run Shimano rear V brake on the front?
 jonb
[#1181593]
Is it possible to use a rear v brake caliper on the front? Or is there a fundamental reason why it won't work. As far as I can tell the cable stop/lock nut will be on the other side but that's not a problem, it might even give me an improved cable routing compared to now!
Time has taken it's toll on my current commuting hack so I want to replace the brakes and have seen the £8 ones on CRC labelled as rear.
Otherwise anyone know of any <£20 v brake sets. I have deore levers and new cables.
Posted : 04/01/2010 12:21 pm
Yes it is possible.
Posted : 04/01/2010 12:28 pm
yea it is fine, the brakes aren't front/rear specific.
Posted : 04/01/2010 12:29 pm
 Kato
It should be the opposite side to the front. My XTR V's are the same arms for either end. Just the noodle is different
Posted : 04/01/2010 12:32 pm
As Kato says, it's just the noodle that is different - front has 135 degree one, and rear just 90 degree. Should be able to get away with the 90 degree on the front possibly.
Posted : 04/01/2010 1:35 pm
Just remember to swap the pads around if they're cartridge type. You don't want the wheel rotoation pulling the pads out of the holders!
Posted : 04/01/2010 1:51 pm
