Is Goretex still th...
[Closed] Is Goretex still the go to breathable membrane?
Millets have some Gore jackets with big savings in their sale.
Posted : 17/11/2020 8:21 pm
Okay - so after the last few days ... I want a waterproof, breathable, well vented jacket (or can be) that doesn’t stain with South Downs mud ....
Moon on a stick??
Posted : 26/11/2020 7:47 pm
I bought a Gore C5 jacket for my CL300 ride and it was perfect, it rained a lot that weekend and I was nice and dry throughout. It is cut very athletic which I like on the bike, less so for walking. Arms are perfect length, the tail could do with a touch more drop though.
I've also the MTR spray pullover jacket and the quality, fit, robustness and arm length are miles away from the Gore jacket but is significantly cheaper.
Posted : 26/11/2020 8:40 pm
Top tip (IMO), always wear a long sleeve baselayer under neath to help the jacket wick away the sweat, if you make that layer thin merino then even better.
Posted : 26/11/2020 8:43 pm
 igm
Daft one for the folk saying you can’t wear a camelback on top of a delicate waterproof.
Since I lost weight, and partly because I already had a Goretex packlite I my pre-weight loss size, I started wearing a camelback vest under my waterproof.
Works well in the rain (slightly more air circulation space) and fantastic at keeping muddy spray off your tools, food, phone, bite valve/water.
YMMV.
Posted : 29/11/2020 1:05 am
So you can’t wear a camelback on top as it’s too delicate, but a huge heavy walking rucksack is ok?
Posted : 29/11/2020 4:49 am
 Spin
My experience of merino is that it wicks very poorly, dries very slowly and that a decent synthetic is far better for any activity where you sweat.
Posted : 29/11/2020 9:20 am
I can see the issue there, grit and shit getting splashed up onto the bag and jacket, and the constant vibration between the two from biking. Not an issue when hillwalking.
Posted : 29/11/2020 11:32 am
Basically what Nobeer says - mud splatters all up your back when biking (even if you have a mudguard, to some extent) and this wears waterproofs out in no time.
Of course if you have the option to ride packless, which is all the rage these days, you'll preserve the life of your jacket. But whatever you do, don't get dirty then put your waterproof on over the top of the dirt, because then the mud gets ground into the fabric from the inside which will trash it in absolutely no time, as I've found to my cost.
Posted : 29/11/2020 1:15 pm
they wet out quicker, but the membrane stays working
Once they wet out they aren't breathing tho (if that's what you meant, they remain waterproof).
Posted : 29/11/2020 2:55 pm
If you want really good breathability, Polartec NeoShell or TNF Future Light, which is a very similar technology based on micro-engineered, spun PU.
Gore-Tex isn't far behind these days and generally more durably/reliably waterproof over time. GTX Pro is a very good balance of breathability, lightness and toughness, but a really noisy fabric and mostly used for top-end mountaineering shells. Active is slightly better for breathability and quieter, but less durable.
ShakeDry comes in a a couple of different versions, the lighter, original one is fragile, the heavier version was developed for hiking use and is tougher, but still not exactly bombproof.
What you do get with Gore-Tex is decades of obsessive development work, really tight quality control and testing of every element of every fabric and hands-on control of factory standards. It also has a lifetime warranty, so if it leaks, take it back.
OutDry is like a much tougher, more durable ShakeDry. Doesn't wet out, but is a lot less breathable ime.
Anyway... different fabrics suit different people and fit, design, cut and features are all important too.
Posted : 29/11/2020 3:18 pm
After all of this I decides to,go cost effective - and bought a waterproof MTB jacket from decathlon. Seemed good spec on paper.
Delivery service from Decathalon was awful - nearly three weeks - and itnhasnjustnbeen sent back.
Nice fit, nice cut, colour ways okay ... but
It has a back and underarm vents - which you cannot seal. The vent itself is about 1 - 2 cds of overlapping fabric under the arms. And about 3cm son the back.
So if you are cycling east, in the usual SDs westerly wind , the water will be blown through the vents. Making it not at all waterproof.
Anyone used Alpkit waterproof jackets ?
Posted : 14/12/2020 7:59 pm
Page 2 / 2
