Is a travel adjusta...
[Closed] Is a travel adjustable fork more useful on a hardtail or full sus?
Generally speaking
Posted : 11/06/2010 2:43 pm
yes.
Seriously - it depends.
Posted : 11/06/2010 2:49 pm
neither ๐Ÿ™‚ ive got talas had them on ht now stuck them on the sus to try but i just dont feel the need to adjust them at all. Maybe depends on the frame
Posted : 11/06/2010 2:50 pm
Nope - Just stick everything in the middle and ride.
Posted : 11/06/2010 2:51 pm
Neither/both.
Its nothing to do with the back end. Everyting to do with bar height at the front. For me, any bike with longer than ~ 120mm forks needs TA to be ridden up proper steep hills. Otherwise the relationship between bars and saddle is all to cock and I can't get enough weight on the front wheel.
Fixed travel forks on my xc bike and SS. adjustable ones on my BFe and Turner.
Posted : 11/06/2010 2:55 pm
Even more seriously - neither, I'd only use one for a long travel bike - 150mm odd.
Posted : 11/06/2010 2:56 pm
Personally I can't be arsed to get off my bike and start twiddling knobs whenever the gradient changes, YMMV.
Posted : 11/06/2010 2:57 pm
I seem to have gone u-turn coils on all my bikes now. (as I don't like air)
I build my bikes up from s/h frames, it's easier to get a good match.
Posted : 11/06/2010 3:00 pm
+1
When I and some mates first got u turn revs that did 130 to 100mm, we spent ages winding them up and down for everything - for the first 3 rides, thereafter they got left at 130mm. If I had 160+mm forks maybe I'd use it, but even my 140mm Pikes are fine if you get a bit of weight on the front, its just a case of adapting technique.
Posted : 11/06/2010 3:03 pm
Depends on bike geometry. I twiddle them down from 130->100 on my TranceX on longer climbs - makes the front easier to handle so is less tiring
Posted : 11/06/2010 3:04 pm
seriously??
i think there is a use for it, for example when i had 150mm forks on my SS i'd lock them down for long climbs because you lose a lot of energy to the compression of the forks which just makes things harder. but on my 150mm FS i don't have lock out on either f or r, i just don't think that you need it if you have proper technique/weighting and see far too many people depending on lockout.
