Rockshox Revelation...
[Closed] Rockshox Revelation Race- set up tips?
[#1695773]
I got some of these off Merlin and put them on last night. Going to set them up later, any know if the air values on the fork are anywhere near accurate?
Posted : 11/06/2010 2:28 pm
 Pook
mine were at 60psi when i put them on. I plunged over the bars. Now at 115psi they feel great. Need to adjust the small bump sensitivity but other than that, yeah they're quite accurate.
If you search for my posts, I did this a couple of weeks back
edit:
http://www.singletrackworld.com/forum/topic/rs-revs-getting-them-set-up
here you go
Posted : 11/06/2010 2:30 pm
I find the recommended pressures to be miles off, searching MTBR will give you some good info, just for the record, I run my 2010 Rev Races with about 85-90psi in the positive and 80-85 in the negative and i'm around 12.5stone.
Best thing is just fiddle until your happy, and don't run more pressure in the negative than the positive as it pulls the fork down.
Posted : 11/06/2010 2:40 pm
Ignore the pressures quoted on the side, they are usually way too high. Also ignore any pressures anyone else might quote because there are WAAAAAY too many variables for them to be accurate for you. 🙂
However, it's not hard to get the right set up for yourself, so [url= https://docs.google.com/Doc?docid=0AVAoGIWBz4H1ZGc5bjJxNTJfMGh2MmtiZGdr&hl=en ]HAVE A READ OF THIS[/url] which explains it all 🙂
Posted : 11/06/2010 2:42 pm
