Is 34 x 34 about th...
[Closed] Is 34 x 34 about the same as 32 x 32?
[#1127312]
As the title says, I'm just getting back into xc/trail riding and my Dialled Alpine has 1 x 9 gearing. My old set up was 32 x 32, but that isn't possible with my LG1 chainguide. So will 34 x 34 get me up hills the same as my old set up?
Posted : 14/12/2009 9:49 am
 mos
Posted : 14/12/2009 9:50 am
yep its the same thing... 1:1
Posted : 14/12/2009 9:53 am
That's great, cheers. Just goes to show how little I know about gears!
Posted : 14/12/2009 10:01 am
you probably have a life instead!!
Posted : 14/12/2009 10:04 am
I think it is the same looking at the gear tables, both combinations give 26" of forward movement for 1 crank revolution.
http://www.machinehead-software.co.uk/gear_inch_ratio_table26.html
Posted : 14/12/2009 10:07 am
It's identical.... No need to look at a gear table!! 🙂
Posted : 14/12/2009 10:12 am
No they don't. You need to multiply by pi to get the forward motion.
The gear inches given in gear tables are the equivalent height of a penny farthing wheel, which would have had the cranks attached direct to the wheel. Simples 🙂
Posted : 14/12/2009 10:23 am
Technically, 34:34 is more efficient than 32:32 but then as stated above, having a life is more important than knowing these 'interesting' facts 😉
Posted : 14/12/2009 10:32 am
34:34 is heavier, the chain goes faster with less tension
BUt the gearing is the same
Posted : 14/12/2009 11:04 am
34:34 is theoretically harder to get up to speed, but easier to maintain a higher speed with lower cadence.
Posted : 14/12/2009 11:06 am
whaaaatttttttttt?
Posted : 14/12/2009 11:11 am
whaaaatttttttttt?
More of the mass is away from the centre of rotation, but it's a miniscule amount.
Posted : 14/12/2009 11:16 am
I'd guessed he might have meant soemthing like that about momentum making it harder to accelerate (wow, it must add 10g to the whole system!), but whats the caddence comment about?
Posted : 14/12/2009 11:24 am
Doesn't 1x9 mean 1 chainring and 9 sprockets?
Posted : 14/12/2009 11:37 am
Yes
Posted : 14/12/2009 12:08 pm
Presumably, the rotating mass means it's easier to keep the pedals spinning roung. Intertia -> momentum.
Real world: it won't make any difference.
Posted : 14/12/2009 12:10 pm
higher speed lower cadence
no way
Posted : 14/12/2009 12:15 pm
I'd have said that the miniscule difference a larger rotating mass would give you would be countered by the minscule extra weight of the largers cog, rings and chain....
My only thing I'd be bothered about would benefitting from the extra groud clearance of a smaller set up
Posted : 14/12/2009 12:18 pm
Oh, I see what he means now. To acheieve the same speed, you don't have to pedal as fast.
Of course, this doesn't apply to the 34:34 or 32:32 question.
Two teeth is going to make naff all difference to the clearance. The circumference of the chainring will be 1" bigger, so the diameter will be 1/pi inches bigger. Half that, and you get the reduction in clearance - 4mm difference.
Posted : 14/12/2009 12:22 pm
Wow, what an interesting thread. 😯
Posted : 14/12/2009 12:26 pm
Without geeks thinking about stuff like this you'd be walking, not riding.
Posted : 14/12/2009 12:27 pm
