Internal cable guid...
[Closed] Internal cable guide straws?
5 Users
Can anybody point me in a direction to where I can buy a length of cable guide straws for internal gear cable routing.
Thanks in advance.
Posted : 04/12/2013 2:52 pm
 SamB
The SRAM pit stop kits come with that sort of stuff, no idea if you can buy it separately though.
Question is, why do you need cable guide straws for internal routing? It shouldn't be rubbing on the frame - there should either be stops at both ends with a clean run of cable between, or a full-length outer run down into the frame... at least that's the case on the two roadbikes I've had with internal routing. What frame are you trying to set up?
Posted : 04/12/2013 3:23 pm
Its for a Ribble R872. Both gear cables run down underneath the bottom bracket sleeve.
I would also like to run a full length piece. To make it easier to re-route next time, and to squirt a bit of wd40 down them to oil/clean cables occasionally.
Posted : 04/12/2013 3:36 pm
 SamB
Hmmm, interesting! First thing I'd do is try to get some spares from Ribble, you'd hope they'd have that sort of thing available.
If Ribble can't supply spares, the nearest thing I've seen is the Gore Ride-on cable system (this replaced the SRAM kits last year I think). Something like [url= http://www.merlincycles.com/bike-shop/road-parts/road-accessories/cables/gore-ride-on-professional-gear-cable-kit-for-road-bikes.html ]this[/url].
They're not quite the same as the Ribble guides (no stops to stop the straw sliding into the frame), but the straws fit snugly onto the ferrule noses so shouldn't go wandering into the frame.
Posted : 04/12/2013 3:47 pm
Transfil black snake cables come with a black 'straw' that helps seal the cables. Plus the inner cables are black which is great for stealth mode.
Posted : 04/12/2013 4:27 pm
 JoeG
I believe that this is what I buy from the LBS
[url= http://www.excelcycle.com/product.php?productid=8491?source=googleps&gclid=CNrm8qKWl7sCFag7OgodJBYAmQ ]Jagwire Seal Liner[/url]
Posted : 04/12/2013 6:14 pm
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=161156550559
Also do a 5m if needed.
Posted : 04/12/2013 6:41 pm
Thanks all.
Ribble could not supply any spares. They are supplied with bike as Ribble recieve them.
Posted : 04/12/2013 8:29 pm
