Instructions on cha...
[Closed] Instructions on changing the lefty hub bearing please, and best type to get.
My 04 vintage lefty hub needs new bearings.
I can't find any guidance[s] on how to do these so wonder if anyone has any guidance they can offer.
Also, the bearings themselves, standard bearings or ceramic. The dimensions and codes can be found so I was considering a trip to a local supplier.
Posted : 05/05/2014 11:34 pm
Remove wheel, take suitable pin spanner and remove the bolt's retaining cap (LH thread, which hopefully won't be siezed) to gain access to the bearings which can be removed/replaced in the same manner as any other cartridge bearing hub ie knock out with a hammer and drift, re-fit with the correct press/socket/handy piece of rock, depending on which school you went to.
Posted : 06/05/2014 6:36 am
Querty cycles are the boys to go to. Quick service, and they have most bits for obscure cannondales (aren't they all obscure?)
Posted : 06/05/2014 8:51 am
http://qwertycycles.co.uk/collections/bearings/products/cannondale-lefty-hub-bearings
Qwerty are out of stock at the moment.
Use STW10 at the checkout when you can order.
Posted : 06/05/2014 8:59 am
What Coatesy said.
I did mine recently and it's no different to any other hub, once you've undone the left hand thread cap.
I'm not convinced that ceramic bearings are worth the money.
I got mine from http://simplybearings.co.uk/
Posted : 06/05/2014 9:01 am
MTG...that second link suggests the bearing should be used in applications of limited rotation, such as suspension linkages. Is that definitely the right one?
Posted : 06/05/2014 8:09 pm
You can get the Cannondale-supplied inner and outer bearings individually if you only need to change one. Both in stock here:
- Outer Bearing
- Inner Bearing
Posted : 07/05/2014 6:18 am
Well spotted, rockhopper70, looks like I bought the wrong one.
It's in the hub now and I've been riding it for a few weeks with no problem.
Posted : 07/05/2014 10:14 am
