Installing CK exter...
[Closed] Installing CK external bottom bracket?
Just installed a new bb. Have never installed a CK before. Got a little confused with the instructions if I'm honest. ๐Ÿ˜•
73mm shell, so no spacers inside either cup. Then had to put 4 metal black spacers outside the driveside cup for the chainline to be right.
Is it right that I should have these parts left over?
The two top ones are too narrow to fit around the spindle, so I guess that is fine. The disc spring though?
Posted : 24/05/2013 1:03 pm
What is that thing bottom left in the pic? Don't think my CK BB has one of those (or the top two for that matter)
Posted : 24/05/2013 1:19 pm
That's called the disc spring according to the instructions. It's a bit confusing...
Posted : 24/05/2013 1:33 pm
The 2 bits at the top are a GXP adaptor kit for fitting Truvativ/Sram
The washer goes on the drive side axle between the bb and the arms on the axle,not sure if its used if fitting to Shimano cranks.
Posted : 24/05/2013 1:38 pm
scott_mcavennie2 - Member
No spacers at all? 73 would usually have one on the drive side, unless CK are different to others.
Posted : 24/05/2013 1:51 pm
That's what I expected HG, but it says:
if installing a MTB-style BB and crankset onto a 68mm shell, install one 2.5mm BB cup spacer onto each bearing cup. No spacers are required for all other setup configurations
Just turned the cranks - it doesn't sound or feel quite right, so I'm going to have a play with the spacers when I get home tonight and see.
Posted : 24/05/2013 2:07 pm
In fact, I should have checked the site to see which bits I need for which crankset:
http://chrisking.com/bottombracket
Doh!Thanks as well nicolaisam
Posted : 24/05/2013 2:09 pm
Travis, just hit it with a hammer. You'll be fine.
Posted : 24/05/2013 2:36 pm
All of the above is part of the SRAM conversion kit supplied with the BB. Usually in a separate little bag. You don't need any of it if not running SRAM/TRUATIV. I have just fitted XX1 and needed all the above for it to work plus four 0.5 thin black spacers you should also have received.
Posted : 24/05/2013 2:48 pm
OK, thanks - that is really helpful. This means I need to remove the 4 thin black spacers which I think means that I need one of the larger spacers on, otherwise my cranks will rattle around ๐Ÿ˜• I think the manual is geared towards SRAM installation, which is confusing. This thread on MTBR suggests I need a spacer on the driveside:
http://forums.mtbr.com/santa-cruz/nomad-chris-king-bottom-bracket-792436.html
Oh well, looks like I get to mess up my lovely CK finish with my shimano BB tool. Can anyone remind me which way to turn? ๐Ÿ™
Posted : 24/05/2013 3:29 pm
One 2.5mm spacer between frame and BB drive side and nothing else.
Just like a Shimano BB and crank on a frame with a 73mm shell.
Posted : 24/05/2013 3:34 pm
Cool. Perfect. Thanks.
Posted : 24/05/2013 3:38 pm
